DNX7100 Review
Old Apr 4, 2007 | 05:24 PM
Spike100's Avatar
Spike100
^^^ Thanks for the reply and the pic.
Just in case someone reading this thread doesn’t know why I asked about the SD slot:
The Kenwood DNX 7100 navigation module does not use DVDs to load application software or map data. Instead, Kenwood chose Garmin as its OEM supplier and licenses the maps from NAVTEQ; and the application software and maps reside in ROM. That means the entire navigation system runs off a memory chip, and that is why it is so fast. Using a SD slot makes it very easy to update the application software and map data. You simply go to Garmin’s website where you can download the latest application software and map data. After doing the download, you write the new files to a SD, and insert the newly written disk into the SD slot on the Kenwood DNX 7100. The DNX 7100 automatically reads the new disk, and does the update. I recently did this (downloaded an update for the navigation module). It was easy (I did it on my computer on the Internet), fast (it took just a few minutes), and provided a valuable update (that included better screen graphics and an update of the NAVTEQ map data base). That was so much better than waiting for a DVD in the mail, and paying for the DVD and shipping.
--Spike
___________________________________
EDIT: For clarification... I did my update using the SD slot on a Garvin GVN 52. It is exactly the same procedure and arrangement on the Kenwood KNA-G510 Navigation "Black Box," or the Kenwood DNX 7100.
Old Apr 4, 2007 | 07:05 PM
THE TECH's Avatar
THE TECH
Spike,
Mando (THEDUKE) swung by today and I saw his LZ-702W. You should definitely consider putting that in and taking the Farenheit out. His setup is almost perfect.
Old Apr 5, 2007 | 04:17 PM
Spike100's Avatar
Spike100
^^ You are correct. Please don't think I'm ignoring your good advice. I just don't want to "jack" the OP's thread here. I'll post a response on Mando's thread.
--Spike
Old Apr 5, 2007 | 05:24 PM
Voboy's Avatar
Voboy
Originally Posted by THE TECH
Spike,
I thought you said that the 7100 won't output Navi though? Will it do it if you have the LZ-702W?
edit: I see your still trying to figure it out.
Old Apr 5, 2007 | 06:27 PM
Spike100's Avatar
Spike100
Well shoot... I was afraid this would happen (and hoping I have not diluted this Thread).
THE TECH and I have managed to add some confusion to the OP's excellent Thread (this Thread) by discussing a different configuration for Kenwood products that is on a different Thread. Where the THE TECH mentions removing the Farenheit, he is referring to this Thread:
https://my350z.com/forum/audio-builds/261207-new-installed-ddx8019-w-lz702w-touchscreen.html
In answer to your question: The DNX7100 displays navigation on its double-din screen and cannot send its navigation display to another screen.
--Spike
Old Apr 6, 2007 | 05:05 AM
THE TECH's Avatar
THE TECH
https://my350z.com/forum/showthread.php?t=261207
--Spike
Correct.
Sorry to the OP if we have taken it off topic.
Old Apr 6, 2007 | 08:16 AM
soleil's Avatar
soleil
NolaZcc
how's the sound quality fo the 7100? the reason i'm askng is because of the 2volt amp outputs? more volts = better quality. i'm planning on buy this today so need input asap
Old Apr 6, 2007 | 08:59 AM
THE TECH's Avatar
THE TECH
I don't know if the novice would know the difference in sound. It will also depend on what other components you plan to use.
Old Apr 6, 2007 | 09:01 AM
soleil's Avatar
soleil
NolaZcc
i actually started a new thread with all of my components.
https://my350z.com/forum/audio-and-video/262066-all-owners-of-kenwood-7100-a.html
tech, can u chime in and give me advice?
Old Apr 6, 2007 | 09:06 AM
THE TECH's Avatar
THE TECH
https://my350z.com/forum/showthread.php?t=262066
Will do.
Old Apr 6, 2007 | 09:07 AM
soleil's Avatar
soleil
NolaZcc
thanks
Old Apr 6, 2007 | 10:05 AM
350Speed's Avatar
350Speed
Hi everyone,
Will this DVD player compatible with factory bose system?
Thanks.
Old Apr 7, 2007 | 06:55 AM
Matt8200's Avatar
Matt8200
Does anyone know why a wire needs to be hooked up to the parking break sensor?
Old Apr 7, 2007 | 07:34 AM
MustGoFastR's Avatar
MustGoFastR
This is the standard safety feature that will only allow the DVD to play when the parking brake in on. To defeat this, simply run that wire to ground.
Old Apr 7, 2007 | 11:15 AM
davidz33's Avatar
davidz33
Does DNX7100 support asian characters?
I have some korean musics and I was wondering if the characters would correctly display.
hulkout
Apr 28, 2017 09:00 PM
nanotech
Oct 2, 2015 05:02 AM
carid
Misc.
Sep 10, 2015 06:16 AM
robbyn
Aug 2, 2002 08:41 PM
