will this box be as good as the zenclosures?
Old Apr 15, 2007 | 01:09 PM
Get_Zwole's Avatar
Get_Zwole
Default will this box be as good as the zenclosures?
http://cgi.ebay.com/ebaymotors/Nissa...ayphotohosting found this and i like the way the Z is on the box wondering if its as good as the z enclosure thanks.
Old Apr 15, 2007 | 01:11 PM
doug's Avatar
doug
without the interior box demensions its hard to tell
Old Apr 15, 2007 | 01:28 PM
Get_Zwole's Avatar
Get_Zwole
yeah i dont think it says anywhere i just didnt know if anybody knew or not i know i hear so many good things about z enclosures it makes me wanna just get one of those but those Z's on there just kinda turn me on somthin different
Old Apr 15, 2007 | 01:29 PM
Get_Zwole's Avatar
Get_Zwole
-Enclosure size = width: 38", height: 11", depth: 10"
-Cutout whole diameter = 9 1/8"
-Mounting Depth = 6 5/8"
-Air volume = .85 cubic ft.
-Chambers = 1
-Structure = 3/4 Medium Density Fiberboard (MDF).
-Carpet = Black high grade automotive carpet.
-Glue = Carpenters wood glue.
-Sealant = Polysemiseal Caulk. AKA (Heavy Duty Silicone)
-Terminal = 1 included.
-Wires = 1.5-3" of XXX oxygen free 16 GA Speaker wire.
-Install time = About 5 minutes.
-Logo = Two original molded Z.
Old Apr 15, 2007 | 02:11 PM
doug's Avatar
doug
zenclosure box has less air space Approximated .75 cubic feet of airspace.
but the back of mike's box is flush and stealth.. http://cgi.ebay.com/ebaymotors/Nissa...0519QQtcZphoto
however mikes other box with the amp rack has more space Airspace: approx. 1.35 cu. ft
http://cgi.ebay.com/ebaymotors/Nissa...8980QQtcZphoto
so to me it comes down to what the back of the other box looks like.. and how much air space you need for the sub you are planning to use
Old Apr 15, 2007 | 02:28 PM
Peak350's Avatar
Peak350
I've got a Zenclosures box specced to just over a cube....VERY happy with the quality. Give Mike a call and talk to him, he was great to deal with and the sub fits nicely.
Old Apr 15, 2007 | 02:39 PM
Get_Zwole's Avatar
Get_Zwole
how much air space do you need with a 10w6v2? the back of the box is flush as well on the other Z box.
Old Apr 15, 2007 | 02:45 PM
Fluid1's Avatar
Fluid1
These are things you should find out before now.
Old Apr 15, 2007 | 02:52 PM
Get_Zwole's Avatar
Get_Zwole
well i dont have the sub yet i dont have the box yet im deciding between two of them. The zenclosures has it listed on there there is a pic of a w6 in the sub on the website so assuming it has plenty of airspace. thanks for all the help though fluid your comment really helped me out alot.
Old Apr 15, 2007 | 02:59 PM
doug's Avatar
doug
http://mobile.jlaudio.com/products_subs.php?series_id=6
Old Apr 15, 2007 | 03:03 PM
doug's Avatar
doug
the owners manual says for seal enclosures 0.625 ft for the 10w6v2-D4
Old Apr 15, 2007 | 06:39 PM
Get_Zwole's Avatar
Get_Zwole
cool thanks alot for your help doug i think i got it all figured out now
Old Apr 15, 2007 | 07:07 PM
doug's Avatar
doug
no prob
Old Apr 16, 2007 | 06:51 AM
StreetOC192's Avatar
StreetOC192
Thumbs up
I have that same xtreme kustoms box. it is very well built. it does have more volume than the zenclosures and still it reamins flush on the front side of the strut bar. nice box
Old Apr 16, 2007 | 06:53 AM
StreetOC192
If the box is .85 and the sub needs .625, then you can measure out and liquid-nails some wood (2x4's, etc) to the inside of the box to bring the internal volume down.
Old Apr 16, 2007 | 01:56 PM
Get_Zwole's Avatar
Get_Zwole
the more airspace wont hurt the sub though will it? cool street oc i just bought it last night so cant wait to get it got all my goodies comin now should have them here hopefully by the end of the week.
Old Apr 17, 2007 | 04:21 AM
StreetOC192
More space won't neceserily 'hurt' a sub physically, but it will alter it's tonality slightly. MOST subs (not all) have about a 10-15% tolerence. So if your sub wants .7 cu ft, then a .85 cu ft is not within tolerence, but it probably won't make 'that' much of an audible difference.
I have a Diamond D6 10 in this same box (.85 cu ft) and Diamond suggests .625 cu ft, and I think it sounds fantastic. I was going to reduce the volume using the method I described above, but figured I would hear how it sounds without doing that first. I have no future plans of reducing the volume.
Old Apr 17, 2007 | 07:04 AM
Peak350's Avatar
Peak350
Larger volume makes the sub louder (and more prone to failure), a smaller volume makes the sub quieter, and to a small extent more precise. But the rec. volume is what you should aim for.
Old Apr 18, 2007 | 05:22 PM
first350's Avatar
first350
Mike (Zenclosure's) makes great boxes...he makes a good selection of boxes w/ different volumes; going w/ a Zenclosure's box gaurentee's quality and service.
Old Apr 18, 2007 | 05:25 PM
Get_Zwole's Avatar
Get_Zwole
well i already ordered the box and the main reason i went with the other guys is because of the Z its different and i think it looks great if you check out a couple pics on his site it looks very clean. Pretty sure ill be happy with it should be here tomorrow.
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
