My radio is REALLY low in volume argggg
Old Apr 22, 2007 | 07:36 PM
Pooplet's Avatar
Pooplet
Default My radio is REALLY low in volume argggg
We just finished my Elemental design install with my buddy david. Everything is fine other than my right passenger window hitting the speaker magnet and my radio being barely audible . The sound is working fine on the CD player but when I switch on the radio I can barely hear anything if at all. I checked all frequencies and the sound is VERY low and reception is terrible. Anyone know what might cause this?
Old Apr 22, 2007 | 08:00 PM
TurboTrey's Avatar
TurboTrey
Did you hook up the antenna amp?
Old Apr 22, 2007 | 08:20 PM
Pooplet's Avatar
Pooplet
are you talking about the antenna plug/jack into the HU?
Old Apr 23, 2007 | 04:28 AM
Lsmith9523's Avatar
Lsmith9523
Pooplet,,,,Along with your Antenna plug/jack, you also have the antenna amp wire that needs to be connected. It does correct your problems. I did the same thing installing my Alpine W-200. After reading here, I took my dash back apart connected the antenna amp wires and BAM,,,great reception. I think the wire is Blue/white,,,,it has been about 8mths ago.
I hope this helps
Old Apr 23, 2007 | 04:36 PM
TurboTrey's Avatar
TurboTrey
Connect the blue wire on the back of the H/U to the radio harness.
Old Apr 23, 2007 | 04:59 PM
nicholasm617's Avatar
nicholasm617
what color is the wire in the stock harness (the plug itself from the back of the bose unit) so i can just jump that straight.
unless any of you know if theres a wire in the aftermarket adapter harness for this antenna amp???
Old Apr 23, 2007 | 09:16 PM
Pooplet's Avatar
Pooplet
yea what color is the radio harness wire? thanks
Old Apr 24, 2007 | 10:42 AM
TurboTrey's Avatar
TurboTrey
Are you using the factory radio or aftermarket? If you are using an aftermarket then the wire is blue off the radio and blue on the harness. This is commonly known as the remote amp turn on wire. Some radios have two wires, one for the antenna amp and one for the remote turn on. All wires are blue. Not sure on the stock harness though. If you are using the stock headunit this wire should be plugged into the headunit and it should be working.
Old Apr 24, 2007 | 01:07 PM
nicholasm617
the remote turn on wire (blue) is turning on my amps, ill probably just splice the antenna amp into the ACC wire.
Old May 5, 2007 | 10:13 AM
stevev58's Avatar
stevev58
I just did this after two months of getting pissed at my head unit for crappy reception and it works like a charm. I was not even able to listen to Am before because I had a lound audible beep and now it is gone.
See noobs the search does work.!!!
350Z_Al
Oct 29, 2020 07:44 PM
Rowlett
Misc.
Oct 2, 2015 10:38 AM
Detailed Image
Cleaning & Detailing
Sep 28, 2015 03:03 AM
