Whats wrong with my speaker?
Old Apr 25, 2007 | 11:41 AM
BakaN20's Avatar
BakaN20
Default Whats wrong with my speaker?
I have alpine type r components, more specifically the spr 176a. I notice that the left 6 1/2 speaker is no longer loud, it is very low. The cone does not move, but when you touch it you can feel it vibrating. Did I blow it? I was running this off a pioneer head unit. What do you guys think is wrong? Thanks
Old Apr 25, 2007 | 11:46 AM
350zspl's Avatar
350zspl
check mid range , tweeter , and crossover connects to see if one is loose
Old Apr 25, 2007 | 12:10 PM
BakaN20's Avatar
BakaN20
I forgot to mention what i did already. I tried connect it directly to the headunit wires, connected it to the other side wires and had the wires connected to the left speaker connect to the right speaker and that works fine. So I am thinking it is the speaker, but anyone know specifically what problems it could be?
Old Apr 25, 2007 | 12:29 PM
350zspl's Avatar
350zspl
if what you did was hook up left side wires to the right side
and hooked up right side wires to the left all this would do is reverse your balance
again in you wiring at some point you may have left something loose
check mid range , crossover , tweeter wires on both sides
and check wire behind head unit
do this 1st
if you already did this than it may very well be the speaker or a short
Old Apr 25, 2007 | 12:54 PM
doug's Avatar
doug
your negative and positives maybe backwards
Old Apr 25, 2007 | 12:55 PM
SpeedRcr's Avatar
SpeedRcr
sounds like the cross over is bad
Old Apr 25, 2007 | 06:03 PM
BakaN20's Avatar
BakaN20
What I meant to say was, lol, I switched speakers. I checked the connections and they are all in the right way. I also used different wires and switched crossovers. 350zspl, when you say short, a short in the speaker? What do you mean? Thanks for all the help guys
Old Apr 26, 2007 | 10:02 AM
350zspl's Avatar
350zspl
possibly a wire has a slice in the jacket and is grounding out on metal
Old Apr 26, 2007 | 12:36 PM
BakaN20's Avatar
BakaN20
I'll give that a try when it gets nicer around here, its been really nasty lately. What do you guys think of this combination then, because I will replace the type r anyways, not my kind of sound:
Infinity Reference 6010cs components
http://www.amazon.com/Infinity-Refer...7618371&sr=8-1
Paired with either an AUDIOBAHN A4002T
http://cgi.ebay.com/NEW-AUDIOBAHN-A4...QQcmdZViewItem
Profile HA1040
http://www.amazon.com/Profile-HA1040...7619773&sr=8-1
Thanks again guys
Old Apr 27, 2007 | 04:40 AM
350zspl's Avatar
350zspl
Profile HA1040
Thanks again guys
i would stay away from profile as i think it is a flea market type unit , you might get engine noise
the audiobahn is one step above flea market and probably won't yeild engine noise
either amp is not money well spent
what do you want to spend for a mid and high amp ?
2 channel or 4 channel ?
how much power do you want to provide ?
Infinty speakers are a good choice , not my choice , but a good choice
Old Apr 27, 2007 | 06:31 AM
BakaN20's Avatar
BakaN20
Lol, I thought that was funny, because there is this really big flea market near my house. I don't want to spend more than $100 for a 2 channel amp, anywhere around 50 rms per channel up to 100 rms.
Old Apr 27, 2007 | 06:53 AM
350zspl's Avatar
350zspl
you may want at least 75 watts rms to your components
if you want a 2 channel you may like these
http://www.sonicelectronix.com/item_...+KAC-6202.html
http://www.sonicelectronix.com/item_...t+PCA+265.html
my choice in 2 ch would be
2005 model
http://www.sonicelectronix.com/item_...nch+P3002.html
2006 model
http://www.sonicelectronix.com/item_...07+Model-.html
if you decide you want a 4 channel so you can power your front stage and rear fill plus be able to balance and fade
http://www.sonicelectronix.com/item_...+GM-6200F.html
http://www.sonicelectronix.com/item_...kt+THA475.html
http://www.sonicelectronix.com/item_...BL+CS60.4.html
my choice would be
http://www.sonicelectronix.com/item_...ch+P450.4.html
but either way all would be better than profile and audiobahn
Old May 2, 2007 | 08:26 PM
BakaN20's Avatar
BakaN20
Thanks 350zspl, I bought Infinity Reference 6010cs Components for $115 on amazon and bought the Blaupunkt 4 channel amp. What do you think of that combo? I am going to take out the speakers in about a week and go to a shop to get them tested to see if they could find out what is wrong. I have an alpine mrd-501 mono amplifier, 275 watts rms, I think I am going to get a kenwood marine subwoofer thats free air compatible and put it in the stock bose subwoofer spot.
Old May 3, 2007 | 04:29 AM
350zspl's Avatar
350zspl
well the blaupunkt was in your $100 budget , is new , and will be better than , a profile , or a audiobahn , for your front mids and highs
why the interest in a Marine Sub
Old May 8, 2007 | 10:25 PM
BakaN20's Avatar
BakaN20
The main reason I was looking at this particular sub is because it has decent reviews from crutchfield, it is free air, and it can handle my amplifier. My amplifier is 275 watt rms alpine mono sub amp. Its pretty cheap too, i heard the bose sub, and it is ok to me, so even this sub should be a lot better than that. I am trying to use a lot of my old stuff and stay relatively cheap. If i mount it in the stock location, it would be easy and save me the trouble of getting a box and it maintains my trunk space, which I really need.
http://cgi.ebay.com/ws/eBayISAPI.dll...MEWA:IT&ih=017
What do you think?
Old May 9, 2007 | 12:22 PM
350zspl's Avatar
350zspl
What do you think?
well i think you can try it
like you said quick , easy and cheap , and save trunk space
if you are not satisfied than we can cross that bridge if and when we get there
go for it
you should at the very least do a search for free air subs see what comes up and compare price
Obadabot
Jun 18, 2023 11:31 PM
3vilbunny
Jul 18, 2017 05:10 PM
