amp power signal
Old Apr 28, 2003 | 01:29 AM
vfr350's Avatar
vfr350
Question amp power signal
ok, stock stereo on an euthusist, no bose no navigation, looking to find a power siganl for my amp, anyone know which wire on the headunit, or is the cigerrete lighter switched power? Anyone had luck tapping a wire to the attenna amp or is that only powered when the radio is on. thanks guys
Old Apr 28, 2003 | 10:30 AM
Jasonj30's Avatar
Jasonj30
Default Re: amp power signal
an easy way to do this, go buy a nissan harness, look which one is the red 12v power wire ( not the constant yellow one) then return the harness
hook that up to the 'remote on' on your amp.
i think is better if you find that radio 12v wire instead of the cigarette lighter. cuz if your car is on and the radio is off, the amp will still be on.
Old Apr 28, 2003 | 12:01 PM
srobert910's Avatar
srobert910
are you looking for a remote turn on lead for your amp or a 12v power lead? If you already have your power lead from the battery run and you need a remote turn on lead, you can get that at the Lighter socket because it's switched with the key. If you're looking for your main power input you shouldn't use anything but power directly from the battery. Hope this helps a little.
Old Apr 28, 2003 | 12:07 PM
vfr350's Avatar
vfr350
just looking for a signal to turn the amp on, running power from the battery, gonna try and fit my kenwood selfpowered tub in the stock sub compartment, should fit. ( low on cash for now, use what ya got right?) Taking the whole thing apart to fatmat the trunk area also, anyone found a "sweet spot" for the ground? thanks again
MAsSIVrOOM
Oct 20, 2023 10:50 AM
sales@czp
Sep 23, 2019 03:30 PM
kyin
Oct 15, 2015 05:54 AM
codek
Sep 28, 2015 03:03 AM
