AVIC-D3 Install Guide
Old May 19, 2008 | 12:53 AM
  #221
BERTO's Avatar
BERTO
I have done the bypass and confirmed that it would allow me to view while in motion. However, I still get a message stating that the unit detected an improper e-brake connection or something. Is this normal? Also, the backround looks like a bunch of grey lines going from left to right, I think it's because the e-brake message I was getting.
Old May 19, 2008 | 01:33 AM
  #222
GSX-R350Z's Avatar
GSX-R350Z
i sort of suck at wiring.
i've been using a lot of butt splice connectors hah...
I was wondering if it was okay if I splice all of the ground wires together and battery wires together?
thanks.
Old May 20, 2008 | 06:21 PM
  #223
GSX-R350Z's Avatar
GSX-R350Z
anyone?
Old May 20, 2008 | 06:25 PM
  #224
j1234's Avatar
j1234
you should be fine to do it that way
Old May 20, 2008 | 09:20 PM
  #225
elcapeo's Avatar
elcapeo
Thanks to orbitalpunk for the installation guide. I'm a novice when it comes to car installation stuff and I was able to complete this myself (for the most part anyway).
Old May 21, 2008 | 09:36 PM
  #226
orbitalpunk's Avatar
orbitalpunk
sup guys, didnt know this was still alive. someone asked about how to get the perfect fit as far as mounting goes. Ill add some updated text regarding drilling wider holes on the bracket. unfortunately i didnt take a photo of the bracket after drilling, but it did look like war zone.
otherwise, im glad this has helped some.
rock on guys.
ps, if anyone wants to add some info to the original post, PM it to me, ill be happy to post it with credits
Old May 21, 2008 | 09:42 PM
  #227
BERTO's Avatar
BERTO
Anyone?
Old May 21, 2008 | 09:49 PM
  #228
j1234's Avatar
j1234
check the ebrake ground
Old May 24, 2008 | 05:06 PM
  #229
GSX-R350Z's Avatar
GSX-R350Z
Just did my install...
so far my PAC SWI-PS doesn't work and my bluetooth isnt connecting to my phone.
Also I have no sound...could someone help me out plz...
Old May 25, 2008 | 01:51 AM
  #230
GSX-R350Z's Avatar
GSX-R350Z
Did my install I can't seem to get the PAC-SWI PS to Program.
I followed the instructions and properly soldered the resistors to the corresponding pin # and nothing.
What I don't get is why we have to solder the resistors to a connector that is not used on the avic D3?
Can anyone answer this please. I have 2 white connectors and a brown connector left over.
Old May 25, 2008 | 02:03 AM
  #231
three's Avatar
three
can u still view video while driving or set directions while driving? i recall having this message and it was cause my bypass had become disconnected. i believe it was the mute wire, it came loose.
i miss my D3!
Old May 28, 2008 | 06:03 AM
  #232
SnyperZ's Avatar
SnyperZ
I have an AVIC D3 and in the stats menu it says the E-brake is on however when I start moving it says its not connected properly. Could this be due to the VSS wire being hooked up? Or maybe my yellow mute is wrong too...anyone?
Old May 28, 2008 | 07:43 AM
  #233
vispre's Avatar
vispre
Moving the mute wire is correct if you followed the directions by the OP. Did you ground Ebrake wire? If you did, i suspect it may have a bad connection, so open it up and re-wrap it (sodder preferrably) and try it again.
Thats all i can think of. Maybe someone else knows more
Old May 30, 2008 | 06:18 PM
  #234
pecx's Avatar
pecx
I have the exact same problem. I just installed it today (5/30/08) I follow every step and pretty sure on what I did. However I have bluetooth installed too. Does it matter? And is there a way to upload a background? My car is 04 non bose non navi
Old Aug 11, 2008 | 10:42 AM
  #235
sajazzman007's Avatar
sajazzman007
DIY'er Unite
Thumbs up Wiring problems
Great write up. I am using this write up to install a Z2 in my 05 350z. Some of the wiring used in the write up I do not have in my car. I am looking for the yellow and black mute wire and do not have one. So what would be the mute wire in my car? Also the VSS wire?
Here are some pics sorry they are blurry.
Old Aug 11, 2008 | 12:00 PM
  #236
sajazzman007
DIY'er Unite
Here are the pictures.
Attached Thumbnails AVIC-D3 Install Guide-image_004.jpg   AVIC-D3 Install Guide-image_005.jpg   AVIC-D3 Install Guide-image_006.jpg   AVIC-D3 Install Guide-image_007.jpg
Old Aug 22, 2008 | 09:24 PM
  #237
J0NNy's Avatar
J0NNy
awsome rightup man
Old Aug 23, 2008 | 04:56 AM
  #238
350z-Jim's Avatar
350z-Jim
Not to steal this threads thunder by any means, it really helped me out a lot. I did make up another related to the BOSE part of the install using a PAC ROEM-NIS2.
I wanted to make a link in this thread so it could be found by others down the road who are searching just as I was a few days ago.
If anybody has a problem with that, I will be happy to delete this post, only trying to help.
Link: https://my350z.com/forum/audio-video...se-no-nav.html
Old Aug 26, 2008 | 02:38 PM
  #239
Eric the Ricer's Avatar
Eric the Ricer
Well, I will have to try the karate chop later. Also, where can I get one of those magnetic pads?
My 03 cubby wont go back all the way, it gets in to the dash about half way, and stops. I'm gonna rip it out in a few days and re-do everything.
Old Aug 26, 2008 | 08:12 PM
  #240
Project3fiftyZ's Avatar
Project3fiftyZ
I was skeptical to do the karate chop at first to but I have to say that it does wonders. If you are still having issues with your cubby going back in Eric you might have some wires that need to be pushed out of the way.
