AVIC-D3 Install Guide
Do I need the Dash kit to install the radio? I have Radio and harness in hand, but not the dash kit. Do I just use the trim once I am done to clean up the look, or does it have parts I will need to actually make it fit?
If it is just a trim peace to make it look good, is it easy to put in after? Becaue I probably won't get it until the end of the week.
Disregard last post. I installed it today. Love it. I also hooked up a zune in the rear cubby as well as an ipod connection in the front cubby. (No need for 2 screens. . . . . . for now.)
Fantastic Post, *many* thanks!
I installed my AVIC-D3 yesterday and I have NO doubt this saved me MUCHO time. By the way, just in case anyone is wondering...
I loves me some Pio AVIC-D3, WOOT! Even BEFORE I switched out the stock speakers, with just the HU swap the sound in the car was improved 1000%, the stock headunit is SUCH a complete and total piece of crap. I can't emphasize that enough. lol
One clarification though, that connector you mention here...
Well, if you're installing a steering wheel control interface, like the PAC SWI-PS like I did, you do need to tap three wires in that plug and ground a fourth. There are two connection plugs "left over" after making up the harness to plug in the D3 to the Nissan wiring, a white one and this one. This is the one that's used.
Anyway, I called it a "clarification" and not a correction, but everyone doesn't have steering wheel controls and some choose not to reconnect them. But if you are doing this install and using/keeping them, that's the connector you need.
Again, all my thanks this DIY saved me untold headaches! If you're ever in Corpus, I'll buy you a beer (or other "adult beverage" of your choice. lol).
Regards.
Regards.
installed my d3 2 days ago with this guide. VERY helpful and clear. One thing though, i bought the metra 80-7550 from circuit city instead of the 70-7550 (they don't carry that one) and was still able to do the vss and bypass. you just have to cut the smart plug end and re-connect all the wires.
thanks again for the tutorial!
I installed bluetooth and XM along with the Avic D3. I placed the bluetooth box directly below the deck, (behind the climate controls). The bluetooth box is small enough to fit below the white controls box. I then ran the microphone out of the bottom left side of the dash, (drivers side), tucked the wire up above where the drivers feet go, and ran it all the way up to my flip down visor. Works perfectly there because it doesn't pickup lots of wind/road noise, it's close to my face so people can hear my clearly also.
Cool, I think I get it. I tried removing panel in front of the driver seat, to the left of the visor and I don't want to break anything. Is there a writeup on how to remove that panel. I am not even sure what its called.....quarterpanel?
edit: I got it, just had to pull hard towards the rear view mirror for the things to unclip and them pull up and out.
I haven't had a chance to install mine, but when I went to circuit city to pick u the iPod cable, they said that I would also be neeing a antenna adapter cable. I am at work so don't have the model no. of the cable but I'll try to put it up when I get home tonight.
Originally Posted by deviljon
does anyone have a problem with the radio signal being very weak and all the stations having a lot of static? how were you able to fix this?
Regards.
Originally Posted by clarkemtp
I'll bet you didn't hook up the Z's antenna module to power? You can use the "power antenna" lead from the headunit to feed it. It's a signal amplifier between the antenna and the headunit. If you don't power it, you'll get exactly the symptoms you describe. Basically, a sketchy signal.
Regards.
Regards.
Exactly...you have to connect the antenna cable (blue) to the power antenna cable (blue w/ white stripe I think)
This will correct your problem of weak signals, and you will be blown away by the clarity of the Avic d3 system!
