PAC OEM-1: RCA Outputs??
Old Aug 5, 2007 | 02:18 PM
Denver350z's Avatar
Denver350z
Default PAC OEM-1: RCA Outputs??
I am currently installing a new HU and I am using a harness and the PAC-OEM1 for the nissan. On one side of the PAC OEM-1 there are 4 RCA outputs and 1 blue power wire.
Where the heck do these go???
On the other side of the OEM-1 (the input) I have all the harness wired together and connected.
Old Aug 6, 2007 | 08:43 AM
Denver350z's Avatar
Denver350z
So I had to abort the install after like 6 hours cause I didnt know what to do the PAC OEM-1. I understand its probably plug-and-play, so I just must be a moron.
Do the RCA cables from the aftermarket head unit plug into the PAC RCA cables? The PAC system schematic shows those cables as being the output, not the input... which would mean they would plug into an amplifier.
I am just thoroughly confused on the subject. I could have finished the install if I did have the PAC adapter, but I want to keep the BOSE and have it work decently for now.
I followed all the walkthroughs posted around here and Tech, but no one really uses the same PAC OEM that I have. They have the NIS2 with out RCA cables.
Old Aug 6, 2007 | 09:19 AM
RedBullRR's Avatar
RedBullRR
Hey Man, PAC-OEM is does exactly that. It converts your OEM radio to give you 2 RCA Jacks for installing an amp.
If you have an aftermarket radio you no longer need the adapter as the aftermarket radio has these jacks.
THEDUKE's Avatar
THEDUKE
I believe the adaptor you are trying to use is for adding an aftermarket amplifier to your factory system. It is not intended for replacing the factory head unit.
Old Aug 6, 2007 | 09:28 AM
JFAIR's Avatar
JFAIR
thats right. you need a "pac-rad-unv". it will alow you to install a am headunit using the pac interface. pm me if you have any other questions.
Old Aug 6, 2007 | 09:49 AM
Denver350z's Avatar
Denver350z
Son of a b****. I knew something was wrong.
I got this - http://cgi.ebay.com/ws/eBayISAPI.dll...MEWN:IT&ih=007
when I should have gotten:
http://cgi.ebay.com/ebaymotors/PAC-R...spagenameZWDVW
crapola. Wasted time.
Old Aug 7, 2007 | 06:23 AM
RedBullRR's Avatar
RedBullRR
Why do you need either 1 if you bought an aftermarket radio. Does it not have the RC Jacks already?
Old Aug 7, 2007 | 06:36 PM
Denver350z's Avatar
Denver350z
I dont know all the details, but its adpats an aftermarket to work with the Bose system. Maybe changes the impedance to 2 ohm or the signal level, not sure. If you do a search on PAC OEM there are some technical discussions on it.
m_0g
Jun 3, 2021 10:05 AM
jlb
Oct 15, 2017 05:10 AM
cashmoney03
Sep 27, 2015 05:24 PM
350zfreak
Dec 16, 2002 02:57 PM
