Question about this amp/sub combo.
Old Aug 15, 2007 | 02:00 PM
Tablist06's Avatar
Tablist06
Default Question about this amp/sub combo.
Would one JL Audio 500/1 amp be able to supply sufficient power to two JL Audio 10" W3V3's?
Old Aug 15, 2007 | 02:22 PM
Tackett's Avatar
Tackett
...I should think so. Whats the RMS and peak ratings on that sub?
Just my two cents here, but I can think of alot better subs to get in the price range of the w3. I think that JL is a big waste of money, if you dont go for highend w6 or w7.
Old Aug 15, 2007 | 03:36 PM
Tablist06's Avatar
Tablist06
The RMS on each sub is 300 watts and 600 watts max. I know that there are many other good subs out there within the price range, but I got a really good deal on a dual zenclosure box. I am also getting a very good deal on the W3's. These are the V3's not the V2.
Old Aug 15, 2007 | 04:22 PM
Tackett's Avatar
Tackett
oh alight I think that amp will be fine. Go for it. Post pics of the install, good luck!
EDIT: crap I didnt read the entire first post. No It wont power both subs. Youll need another amp. Or a two channel
Old Aug 15, 2007 | 04:42 PM
Tablist06's Avatar
Tablist06
Yeah, I guess I'll have to look for a 2 channel amp then. Thanks for your input bro!
Old Aug 15, 2007 | 06:41 PM
Tackett's Avatar
Tackett
glad to help try woofersetc.com they have good stuff
Old Aug 16, 2007 | 06:29 AM
StreetOC192's Avatar
StreetOC192
1 500/1 will be sufficient for 2 10w3v3 subs. Each sub will see 250 watts which is well within the optimal range suggested by JL Audio. the 50 watt difference between 250 watts and 300 watts MIGHT yield a 0.5 dB drop in sound level (inaudible by most living organisms)
Old Aug 16, 2007 | 08:00 AM
Tackett's Avatar
Tackett
You could...most companies rate their amps at peak wattage and not RMS, so I was assuming the amplifier he mentioned only pushed around 200 watts RMS and 500 peak. I guess I'm just always afraid of under powering speakers, then you will just wind up buying another amp after you melt the one you have anyway. Ive always been of the logic "spend more money now, spend no money later."
Old Aug 16, 2007 | 10:02 AM
Tablist06's Avatar
Tablist06
JL actually rate their amps at RMS. So yes, it will be pushing 250 watts to each sub. Thanks again guys.
Old Aug 16, 2007 | 10:07 AM
blasian's Avatar
blasian
I remember reading somewhere the 500/1 is under-rated.
That will be plenty enough, my buddy is running the 500/1 on his W3v2's....
Old Aug 16, 2007 | 10:59 AM
Tackett's Avatar
Tackett
I stand corrected...apologies.
issyz
Jul 2, 2017 03:04 PM
Alexreyes
Sep 30, 2015 11:30 PM
Conway_160
Drag
Sep 29, 2015 08:07 AM
