killer switch?
Old May 14, 2003 | 12:26 PM
pierreb's Avatar
pierreb
Default killer switch?
do you think it is a good idea to wire the fuel pump with a killer switch?
if yes, any idea where NOT to place the switch to make it more difficult for thieves?
a co worker just had his car stolen today...
thanks
Old May 14, 2003 | 02:46 PM
toykilla's Avatar
toykilla
hmmm thats interesting. ... i would say be creative as to the location, somewhere you can easily reach but very well hidden. ... i dont know what adverse affects this would have if any
Old May 14, 2003 | 05:18 PM
all_bark's Avatar
all_bark
put it in the change drawer!
Old May 14, 2003 | 05:19 PM
all_bark's Avatar
all_bark
when closed it is out of sight!
Old May 14, 2003 | 06:22 PM
alphared's Avatar
alphared
Uh, I think thieves would be looking in the change bin for change.
Old May 14, 2003 | 10:02 PM
jeffa's Avatar
jeffa
You don't need a kill switch.
The key has a transmitter in it that has to match a receiver in the Z's BCM unit. If they don't match, no start. It is almost impossible to hotwire a Z to steal it. The thief has a better chance flatbedding the Z than hotwiring it.
Oh yeah, forget about trying other keys...the code changes each time the key is used, and after three trys with the wrong codes, the ignition locks out for a preset time...
Old May 15, 2003 | 03:36 AM
Daewoo's Avatar
Daewoo
not to mention ... if u r that concerned just take the fuel pump fuse out when u r in a questionable area. If like other nissans it should be in the cabin easily accessable.
Old May 15, 2003 | 07:15 PM
Encore's Avatar
Encore
I had DEI's Car*Com on my mr2 spyder. Any thing I could do from my alarms remote I could do over the telephone. I had my fuel pump hooked up to my alarm so I could kill the car over the phone in case I was to get "car jacked". I also had a kill switch hidden under my shift boot that I could barely fill, and you had to know exactly were it was. Very hidden. I never even told my best friends about it. As far as the immobilizer in your key. That only helps if someone doesnt have your key. What if you get robbed at your car, your kids snag your key while your asleep, someone has dupicate key, etc. I have one or more keys from every car I ever owned.
Old May 16, 2003 | 01:31 PM
MastaKillaZ's Avatar
MastaKillaZ
If the immobilizer function supposedly cannot be circumvented, then how are all the 350z owners with the viper xv-790 or similar remote start system making use of the remote start function via their alarm controls???
If they can work around it for remote start, can't they presumably also hotwire the car??? I don't know much about electronics so that's why I'm asking.
Old May 16, 2003 | 02:55 PM
jeffa's Avatar
jeffa
The DEI remote start uses a hideaway module that sends a signal to the immobilzer circuit in the car ONLY when you use the DEI transmitter to start the car. After the car starts by remote control, the module is disconnected from the immobilizer circuit. Any other time, the module is inactive, giving you the same security level as if the remote start was not there.
Also, Encore, if someone were to carjack me at gunpoint, I would want them as far away from me as quickly as possible. Having a kill switch under this situation is not good. You can always replace the car, but you can't replace your life!
In this situation, a GPS tracking system, or Lojack would be a better solution than a kill switch...let law enforcement get the bad guys and recover your car.
Old May 17, 2003 | 05:31 AM
Encore's Avatar
Encore
In this situation, a GPS tracking system, or Lojack would be a better solution than a kill switch...let law enforcement get the bad guys and recover your car. [/B]
If you read my post you would see my kill switch was controlled by telephone. So that should give them plenty of time to be out of my way + the car would be easier to locate since it would more than likely be in the middle of the road w/ light flashing horm honking, and siren blasting. I didnt know if you had caught that part. I agree someone with a gun pointed at me the farther away the better, but getting to a phone, and calling my car should give me enough time to be out of harms way.
Workshop12
Mar 23, 2020 01:45 PM
Beater350z
Sep 9, 2015 03:36 PM
AP350z223
Sep 8, 2015 04:38 PM
