Amp wont turn on!!!
Old Oct 14, 2007 | 05:29 PM
hamsuplo's Avatar
hamsuplo
Unhappy Amp wont turn on!!!
Hi guys,
I am totally stumped because i dont' know why my amp isn't working, 2 weeks ago, i was cruising around chilling when all of a sudden all the sound goes out in my car (i wasn't blasting it), at first i thought it was my head unit but it looked like it was still working, as was my ipod, so i thought damn my amp blew, i went back to the place i got my amp from and they gave me a new one, i got home and plug it in and it STILL doesn't work. So i thought i had a bad ground, i sanded down the area and it still not working (its sunday so i cant get any more cable to try to ground it anywhere else). I tried dragging new wire for the remote cable thinking thats why the amp wouldn't turn on, still nothing. I'm incredibly angry and really don't know what to do.
does this seem like a grounding problem? anyone know a good shop that wont charge me an arm and a leg around NYC?
here is my setup:
6.5 soundstream speakers all around
alphasonik 400 series 10" sub in a Zenclosure understrut box
alphasonik pmz120005 5 channel amp
Avic-N1 with n3 software
any help would be GREATLY appreciated!!
Old Oct 14, 2007 | 05:37 PM
HIGHTECHZ's Avatar
HIGHTECHZ
use a multimeter or a voltmeter and make sure you are getting 12v from the constant and switched (aka amp turn-on or remote wire), and test that the ground is actually grounded. If it still wont turn on, then it is the amp that is bad. BTW a fuse can look ok and actually be blown (first thing I would check).
If it turns on and then goes out, check that the speakers hooked up to it aren't grounding out or overloading the amp.
All I got.
Old Oct 14, 2007 | 05:41 PM
RedLine 350z's Avatar
RedLine 350z
Get this and test both your power and remote wire to the amp.
http://chinafuhaote.en.alibaba.com/p...it_Tester.html
It might just be your amp live wire blew a fuse or something wrong with your remote.
Old Oct 15, 2007 | 12:57 AM
Tomci08's Avatar
Tomci08
i would start by checking the fuses, both the inline on the power cable and the fuse taht is occasionally on the amps themselves. If that doesn't help go with the voltmeter and test everything out just as stated above. If that doesnt work i would just retrace every wire and make sure it is not damaged or make sure it connected properly. Hope you get it working.
Old Oct 15, 2007 | 08:20 AM
NoahzBurnt's Avatar
NoahzBurnt
i say check the fuse near the battery. Aslo check to make sure the power wire hasn't come loose from the +12V terminal
loudtoyz
Apr 6, 2023 04:52 AM
sherm
Apr 11, 2020 05:21 PM
Depravity
Oct 1, 2015 04:49 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
samansharif
Sep 25, 2015 12:31 PM
