Need HELP with Blinking AirBag Light!!!
I recently gutted my car on the inside to install a full stereo system to replace the POS Bose from factory. Now that I am done and everything is back together the Airbag Light keeps blinking. So I figured that maybe I forgot to plug a cable, after uninstalling the center console and dash again to make sure Nothing, everything was plugged properly. I then disconnected the battery for at least a minute and applied the brakes to kill the juice in the car hoping that that would reset the airbag sensor memory, but it didn’t.
1. Has anyone encountered this problem?
2. Any ideas that might help me solve this issue?
3. Where is the Airbag Sensor located at?
4. How do I reset the Airbag sensor?
I don't know why, but i think I had to turn the key on and off (off to on, but not started) 5 times quickly to get rid of the light.
The answer is on this board somewhere. Search around.
Thanks for the help, I will try that.
I just tried that and it didn't work.
1. Leave your door open.
2. Put your key into the on position.
3. The air bag light will blink after 4 seconds. But just wait till you see it start to blink.
4. turn your key to the off position.
5. Listen to the chime from your door, for 7 chime or seconds. Thats how i count my seconds.
Theb repeat the steps 4 times. That should reset it. If not then you have a problem.
