roadster sub swap....
Old Oct 20, 2007 | 12:49 PM
chortik2's Avatar
chortik2
Exclamation roadster sub swap....
i wanna change my bose sub for a kicker cvx10... but i dont wanna spend 300$ for a custom box! any suggestions???
Old Oct 20, 2007 | 01:04 PM
r0mey's Avatar
r0mey
yea spend the 300 bucks and get it done right dont take the cheap way out trust me its worth it
Old Oct 20, 2007 | 02:55 PM
chortik2's Avatar
chortik2
well **** man....
are there any places anyone knows where to get a custom box for the zr? =/
Old Oct 20, 2007 | 03:11 PM
r0mey's Avatar
r0mey
i gotta run out but pm me ill get back to you with the info i have a zr too. there are a few places
Old Oct 21, 2007 | 11:53 AM
steelcity's Avatar
steelcity
Has anyone had problems with their stock sub going in and out? When it goes out, I normally can pound on the cover and it will start working again. So, I thought it was a loose connection, but just took it apart. The connections seem to be ok, so wanted to see if anyone else experiences this problem.
Any help would be greatly appreciated!
Old Oct 22, 2007 | 11:02 AM
chortik2's Avatar
chortik2
yea.. thats exactly what happened to me and i kept doin that for a while.. now the sub wont cut in at all anymore... thats why im now jjust saying fck it, im replacing it =/
Old Oct 22, 2007 | 12:05 PM
StreetOC192's Avatar
StreetOC192
Get the WickedCAS box from Nazar and call it a day. you will be much happier and it will take a LOT less work and effort on your part to try and seal the cubby properly. It will cost a bit more than you might want to spend, but it will be done right.
Old Oct 22, 2007 | 12:59 PM
chortik2's Avatar
chortik2
yea.. thats the 300$ box =/
Old Oct 22, 2007 | 01:03 PM
iStan's Avatar
iStan
ZR
Haha, it's going to be the same answer https://my350z.com/forum/350z-roadster/308663-help.html
Old Oct 22, 2007 | 03:16 PM
chortik2's Avatar
chortik2
Originally Posted by istan
Haha, it's going to be the same answer https://my350z.com/forum/showthread.php?t=308663
yea, u caught me.. i was hoping for a diffrent answer =/
Old Oct 22, 2007 | 04:04 PM
StreetOC192
If you are good with fiberglassing then you could glass your own enclosure. It would probably only cost you about $80 in materials + cost of sub. You might be able to mimic the wicked cas design with the down firing sub (recommended), or you could make the sub front firing (but it prob won't sound as good).
Old Oct 23, 2007 | 04:39 PM
TurboTrey's Avatar
TurboTrey
Good luck finding a different answer here. I think it's funny that people don't slam roadster owners for putting subs in their Z.
Old Oct 24, 2007 | 12:26 PM
chortik2's Avatar
chortik2
and y would you? =/
are you one of those coupe owners whos jealous bc he couldnt afford the roadster and now ur just trying to pick an online fight?
anyway... i've never worked with fiberglass, so thats prolly not a good idea =p
if i just replace the bose sub with a kicker sub,and replace the amp, no crazy enclosures, just bolt it right in where the bose was.... u guys think it will really sound like ****? =/
Old Oct 24, 2007 | 12:52 PM
StreetOC192
and y would you? =/
YIKES!!!
A quick browse through the audio section will tell you the answer you will get here. The consensus here is that it sounds like hot poo. This of course is a personal opinion because everyone has their own standards of what sounds good. All I can tell you is to try it out. Buy a sub and amp and try it. If you like the sound it provides, then you are done. If you think it sounds like poo, then look for an alternative like fabricating your own box or buying the premade WickedCAS box.
Old Oct 25, 2007 | 03:38 PM
chortik2's Avatar
chortik2
tru... and thats what im probably going to end up doing... but i have a feeling im going to want a box and is there really no other boxes out there?
Old Oct 25, 2007 | 03:43 PM
StreetOC192
Unfortunately not. It is quite a labor intensive process to make an exact fitting fiberglass box. That's why the high price on the WickedCAS box.
MAsSIVrOOM
Oct 20, 2023 10:50 AM
jlb
Oct 15, 2017 05:10 AM
BumbleZee
OZOC (Orlando Z Owners Club)
Sep 26, 2015 01:00 AM
416blueZ
Sep 25, 2015 10:00 AM
