Which sub is better for me?
Old Dec 17, 2007 | 10:54 AM
freemanjc's Avatar
freemanjc
Default Which sub is better for me?
13Ov.2 Subwoofer or JL Audio 12W3v3-4 running off a Alpine MRP-M650
600 watts RMS x 1 at 2 ohms) Thes are the only two I am considering becuase of the max mounting depth of 7.125.
Thanks
Old Dec 17, 2007 | 11:00 AM
TheBlackPearlZ's Avatar
TheBlackPearlZ
Jl Ftw!!!
Old Dec 17, 2007 | 11:48 AM
StreetOC192's Avatar
StreetOC192
I would take the eD 13Ov2 over a JL w3 series.
Old Dec 17, 2007 | 01:47 PM
freemanjc's Avatar
freemanjc
1 point for each, some one care to be a tie breaker!
Old Dec 17, 2007 | 03:08 PM
doug's Avatar
doug
Old Dec 18, 2007 | 06:42 AM
freemanjc's Avatar
freemanjc
Originally Posted by doug
What does the RED X stamd for?
Old Dec 18, 2007 | 06:47 AM
freemanjc's Avatar
freemanjc
Default Eclipse SW7200 opinion
Does anybody have any opinions on the Eclipse SW7200 12 inch Subwoofer
(4ohm + 4ohm)
Old Dec 18, 2007 | 07:05 AM
kspec's Avatar
kspec
im about to install a 12" kicker l5 in my Z today most likely.
You interested in that kind of sub? i can give you feedback just for the heck of it later on.
alot of people here seem to go with 10".. Im going to try a custom box with this 12" and see how it sounds.
Old Dec 18, 2007 | 07:21 AM
doug's Avatar
doug
means you need to update your browser because there is no red x here
Old Dec 18, 2007 | 07:23 AM
kspec's Avatar
kspec
lol idk if that pic is worth fixing a browser for...........
JL audio..
JL Audio seems to be on par with budget brands like MTX. idk.
just my opinion. idk much about JL audio tho.
Old Dec 18, 2007 | 07:30 AM
k6750gsxr's Avatar
k6750gsxr
jl is a name... there are plenty better out there.... ie.... elemental design.... awesome subs.....
Old Dec 18, 2007 | 07:32 AM
kspec's Avatar
kspec
yea elemental designs are tight.
their christmas special had INSANE prices...
if you sign up at some forums, you get a discount off elemental design products also.
I was thinking about buying from them also.
Old Dec 18, 2007 | 09:01 AM
freemanjc's Avatar
freemanjc
Well I decided to go with the 13Ov.2 Subwoofer it should be here tommorrow!
Thanks all
Old Dec 18, 2007 | 09:23 AM
StreetOC192
JL audio..
That's kind of what the pic is all about
Old Dec 18, 2007 | 10:06 AM
freemanjc's Avatar
freemanjc
Street OC,
Somwhere I got lost in all of this!
Thanks for all your help again!
Old Dec 18, 2007 | 10:28 AM
StreetOC192
Street OC,
I hear ya, i kind of followed your posts about using a 2-10" box, then you went to 1-12" box and which sub you wanted and reducing the volume in your box. It's not easy to make up your mind all the time.
So I think the final verdict is you are going with:
XtremeKustoms single 12" box, and reducing it from 1.5ft^3 to approx 1.0ft^3.
eD 13Ov2 12" subwoofer.
Did you decide on the amp? Are you keeping the Alpine? I think the Alpine will work fine on that eD sub.
Old Dec 18, 2007 | 10:47 AM
freemanjc's Avatar
freemanjc
Yes, after alot of pounding the box last night with extra slabs of wood I think I might have gotten it down to 1.1 -1.25, we will see. I guess I will just have to wait and see. I am going to keep the Alpine amp. I am tired of spending money on things that are really pointless but I like music and I am convinced a 10 inch sub will never satisfy my taste that a 12 inch would.
One question though, since I have two 10 Type R' now and each is hooked up to it's own independent Alpine amps when disconecting the other amp to go down to one do I just disconnect the other amp from the Distribution block and take out of the car or do I need to completely rearrange RCA jacks behind the deck too.
R,
Julius
Old Dec 18, 2007 | 11:05 AM
StreetOC192
Well, when removing the amp, you are going to be removing the power, ground, remote turn on, and rca cables for the amp being removed. I am not sure how your rca's are coming off the headunit to the 2 amps. did you use a Y-splitter?
Old Dec 18, 2007 | 11:14 AM
freemanjc's Avatar
freemanjc
OK, I 'm not sure how it's ran, I do have a passive EQ though. Here is a stupid question, couldn't I run each amp to each voice coil then?
Old Dec 18, 2007 | 11:19 AM
StreetOC192
You could in theory, but it's NOT advisable.
