Kenwood Video Units Ipod Update
Old Jan 4, 2008 | 12:30 PM
THEDUKE's Avatar
THEDUKE
Default Kenwood Video Units Ipod Update
For those of you that have the Kenwood Video units especially the DNX7100 and have the newer ipods the update is now available. It is a firmware update that will need to be downloaded onto you computer. You load that update into a flash drive and stick it into the USB port of the unit and you are ready to start. For most of you the USB port will be the plug where the Ipod adaptor is plugged into. If the unit was installed with some thought in mind you should not have to remove the unit to do this, for the rest of you have fun. Just a side note it is compatible with the Itouch, but it will not do video off the Itouch, this is an Apple issue not an Kenwood issue. Evey other manufacturer has the same issue with the Itouch. Once again this is a firmware update for the Ipod firmware only and will not have anything to do with mapping updates. Here is the link for the updates
http://www.kenwood.com/usb/info_program_en.html#visual
Old Jan 4, 2008 | 01:58 PM
DavesZ#3's Avatar
DavesZ#3
Is this update required for the iPhone to work with it?
Old Jan 11, 2008 | 03:26 PM
fizmixa's Avatar
fizmixa
the iphone does not currently work with my unit. i'm assuming this update will fix that. will find out tomorrow when i do the update.
Old Jan 11, 2008 | 03:45 PM
DavesZ#3's Avatar
DavesZ#3
Please let me/us know. I was thinking about buying an iPhone this weekend. Isn't there a special cable/adapter needed to connect the iPod (and I assume iPhone) to the connections out of the 7100?
Old Jan 11, 2008 | 03:53 PM
THEDUKE's Avatar
THEDUKE
It will work with the Iphone, but has same issue as the Itouch it will not do video off the Iphone.
Old Jan 11, 2008 | 08:59 PM
fizmixa's Avatar
fizmixa
yeah, you need an adapter. either one of these will work:
http://www.crutchfield.com/S-QzqQpU3...sp?i=113IP300V
http://www.crutchfield.com/S-QzqQpU3...sp?i=469KNWUSB
no video?! that's bunk.
Old Jan 12, 2008 | 03:55 PM
fizmixa's Avatar
fizmixa
just updated my head unit. iphone does work now with the kenwood, but it is a little flakey probably because my iphone software is not at the level kenwood recommends which i believe is 1.13 (won't know for sure since i won't be updating my iphone since its unlocked). album art isn't being displayed. also the current track information does not change or show the elapsed time. it shows the correct track info for the first song i play but when i skip to the next song, the info doesn't change. music plays fine though. guess i'll just continue to use my 2nd gen nano for the kenwood..
Old Feb 23, 2008 | 07:09 AM
Sick Z's Avatar
Sick Z
Hey Fiz, which one of those cables did you use for the iphone? From what I have read, you need the KCAIP500 cable to be able to use the iphone on the DNX7100. Does your cable charge the phone, display the artist etc, on the HU?
Old Feb 23, 2008 | 08:31 AM
fizmixa's Avatar
fizmixa
i'm using the P.I.E. ipod cable. the place i ordered stuff from only had that one in stock, not the kenwood one. i was told they both do the same thing. i have no issues with the iphone connected. it charges, it displays the album art on the dnx7100. i upgraded my iphone software to 1.1.1 recently, so that helped with the issues i initially saw after updating the dnx7100. also, when connecting the iphone, you get that message that the iphone is not compatible with the device it is connecting with and if you want to turn on "airplane mode." i just choose no and have yet to run into any problems. hope this helps..
Old Feb 23, 2008 | 08:58 AM
THEDUKE's Avatar
THEDUKE
The KCA-IP500 is NOT the correct cable for the DNX7100. You need the KCA-IP300V.
Old Feb 23, 2008 | 09:01 AM
Sick Z's Avatar
Sick Z
thanks for the info fix and duke. I believe the 500 cable is the older version, but I read a post on the dnx7100 thread that it was the correct cable for full functionality. the KCA-IP300V is pretty much the same cable as the one fix uses but has the video output as well. Has anyone been able to use videos from the iphone to the HU?
Old Feb 23, 2008 | 09:20 AM
fizmixa's Avatar
fizmixa
sickZ - you will not be able to play video off of the iphone as Duke stated in one of his earlier posts. i can confirm that the dnx7100 cannot play videos off of the iphone as you will not see this option.
Old Mar 17, 2008 | 11:41 AM
jiggalam's Avatar
jiggalam
ok so im screwed with the usb cable, since it was installed by someone else, most likely in the back. can i use the sd card to update the firmware?
Old Apr 21, 2008 | 05:14 PM
twinship's Avatar
twinship
Anyone know the answer to this?
I'm in the same boat... no access to the USB port w/o pulling the unit out of the dash.
Old Apr 22, 2008 | 08:10 AM
THEDUKE's Avatar
THEDUKE
The answer is no. The SD slot is dedicated only for Navigation updates.
Old Apr 22, 2008 | 08:31 AM
twinship's Avatar
twinship
Ouch, not what I was hoping to hear!
Thx for the info, tho.
Old Apr 22, 2008 | 08:57 AM
azula's Avatar
azula
i have the latest generation ipod (classic) and it works fine without the firmware upgrade....what exactly is this firmware upgrade in relation to the new ipod??
Old Apr 22, 2008 | 09:05 AM
twinship's Avatar
twinship
It's possible your unit has the latest firmware (v. 1.0.9).
I have firmware version 1.0.4 and with my iPod Nano, the performance is very flaky. Sometimes it fails to authenticate, I usually can't view a list of songs, the name of the currently playing song doesn't update when the next song plays, etc.
PITA.
Old Apr 22, 2008 | 12:29 PM
token5gtd's Avatar
token5gtd
i updated the firmware on my ddx8019 and now the iPod menus are a little quirky...sometimes when i hit playlists it will go to songs, or when i select a folder it will not show the song names just blank spaces... i'm thinking it's my iPod. i've had it for a while, it probably needs to be updated itself
Old Apr 22, 2008 | 03:59 PM
DavesZ#3's Avatar
DavesZ#3
Originally Posted by token5gtd
... thinking it's my iPod. i've had it for a while, it probably needs to be updated itself
I believe when you download the Kenwood update, it warns you about the version you need on your iPod/iPhone/etc.
Workshop12
Mar 23, 2020 01:45 PM
May 30, 2017 03:28 PM
Justin100
Nov 29, 2015 03:58 PM
dcains
Nov 11, 2015 11:36 PM
