mtx or RF
Old Jan 4, 2008 | 02:24 PM
b-ron's Avatar
b-ron
Default mtx or RF
the shop thats doing my system is putting in 2 MTX T7510-44
10" 800W Dual 4-Ohm Subwoofer
Sensitivity: 90.6 dB
RMS Power Range : 400 Watts
Peak Power Handling: 800 Watts
Impedance: Dual 4 Ohm
Low Frequency response: 47 Hz
High Frequency Response: 150 Hz
i have 2 rockfordfosgates P3 sitting at home from my previous car
Sensitivity: 85 dB
RMS Power Range : 100-400 Watts
Low Frequency response: 20 Hz
High Frequency Response: 200 Hz
Diameter: 10 Inch
is it worth me paying 260 each for the mtx when the P3 is 165 a sub? will it be that much more of a sound dif. from my P3.
Old Jan 4, 2008 | 03:51 PM
smaha's Avatar
smaha
Hail NO! I don't always put a lot of faith in stats.......BUT if your sub only hits to 47hz, you're not going as low with your subs as my component set. Save your money and stick with the RF's and spend those 5 bones on another mod.
Old Jan 4, 2008 | 04:21 PM
b-ron's Avatar
b-ron
sounds good to me!!!!!! because my headunit is putting me out 1400 lol
Old Jan 6, 2008 | 09:49 AM
StreetOC192's Avatar
StreetOC192
Well actually the freq. response specs of a subwoofer are the freq. range a driver can play in free air without a change in dB of +/- 3dB. The MTX is rated at 90.6dB vs the Rockford 85dB, so the MTX can lose 3dB in freq. response and STILL be playing that frequency louder than the Rockford. MTX has always rated their subs at the higher dB level because they do play louder in the 'meat' of the freq. range of a subwoofer. I'm sure if they rated at 85dB like Rockford it would probably have a low end extension around or lower than the Rockford p3.
But to the OP, just save the $$ and stick with the Rockfords unless you were unhappy with their performance in the past.
hotsonhk
Sep 5, 2007 06:38 AM
leatherface_ca
Southern California
Dec 14, 2005 12:38 AM
trefittyZ
May 11, 2005 11:51 PM
lopchild
Jan 3, 2005 07:58 PM
ooohhh
Apr 7, 2003 05:51 PM
