PUSH BUTTON STARTER: Ignited?
Old Jan 5, 2011 | 11:11 AM
  #41
PENJrAV8R's Avatar
PENJrAV8R
i will be on board when it is truly keyless.
Mazda used a flat remote that fits in your wallet combined with a permanent plastic key-like switch where the key normally goes. without the remote, turning the switch does nothing. with the remote, the switch starts the car like a regular key.
I was thinking of adding a signal booster on the car end of the transceiver to increase the range. I would then place the transponder in the door remote fob. this way, the transponder should be able to operate by simply being IN the car. the remainder of the key I would affix to the ignition and buy or make a cover similar to the Mazda switch to make the ignition look pretty. this way the remote can stay in my pocket while i drive.
I am not sure if the nissan would freak out if the signal was lost or diminished while the car was on. I also am unsure if I could boost the signal enough to do this.
If anyone has any expertise in this area or additional ideas, let me know.
Old Jan 7, 2011 | 05:57 AM
  #42
ETZ's Avatar
ETZ
http://www.auto-innovatio.com Totally keyless, check out the video's
Old Feb 21, 2012 | 07:25 PM
  #43
lotteman's Avatar
lotteman
disregard this post
lolwatbro
Oct 9, 2021 04:58 AM
Workshop12
Mar 23, 2020 01:45 PM
Katie93
Sep 15, 2015 05:57 PM
