First Audio Modifications?
Old Jan 14, 2008 | 01:01 PM
Justinw1313's Avatar
Justinw1313
Default First Audio Modifications?
I just bought a 03 touring edition 350Z and I was wondering what I should start with in my modifications to the audio system.
I have an 05 Kenwood deck and 2 10" JL Audio subs. Im not sure if I really want to install either of these in my Z.
My goal is not to vibrate my testiculars off, but to make a clearer and a little louder than stock system.
I have about $500 to spend, and I was thinking either a decent deck and maybe some new door speakers? Any suggestions to a beginner?
If Im not going for a rediculous system should I get rid off my 10" JL Audios and old deck to help offset the costs? Or find a way to use them?
Old Jan 14, 2008 | 03:42 PM
ev0k1ll3r's Avatar
ev0k1ll3r
most people say lose the bose
Old Jan 14, 2008 | 03:44 PM
SuperBlack350z's Avatar
SuperBlack350z
i would just get an amp for your subs that you already have. The bass doesn't have to be loud or boomy. You can control that.
Old Jan 14, 2008 | 04:05 PM
Spike100's Avatar
Spike100
I believe the 2003 Touring model came with a Bose system. That requires replacing everything since the Bose is proprietary and it’s components won’t work properly with non-Bose devices.
If your budget is tight, you could use the Kenwood deck, add an amp, replace the front component speakers - and disconnect the rear speakers, the Bose sub and it’s little amp. From there you can add the SubWs you already have.
I’m suggesting the you keep the Kenwood and your SubWs since you already have these, and you can always swap them out at a later date if you want. They are much better than the Bose you have now in your car.
--Spike
Old Jan 14, 2008 | 04:45 PM
doug's Avatar
doug
buy a set of front components for $150.. use the rest to buy a 4 channel amp... run the fronts of 2 channels... run the subs of the other 2..
hopefully you can install this stuff yourself.. if not then keep saying because install alone is going to cost you a pretty penny
Old Jan 14, 2008 | 04:49 PM
Justinw1313
I had no idea the bose system was an exclusive system. I guess I better save up and get a good amp, and door speakers. Does anyone know if my 10" subs can be fitted into the stock bose speaker holes directly behind the seat? Ive seen a couple boxes that pretty much took the entire cargo area. As this is my fiance's daily driver I don't want to sacrifice the limited supply of cargo area that the Z has.
Old Jan 14, 2008 | 05:02 PM
doug's Avatar
doug
the bose location is a sh!tty location.. you won't get the proper performance out of your subs in that location.. get an under the strut bar box
Get_Zwole's Avatar
Get_Zwole
they make a box for that area do a search for it im too lazy at the moment if not ill get you a link in a bit. They are pretty expensive boxes though. The understrut 2 10 box doesnt really take any cargo area at all just like it says under the strut. You dont have to get the amp rack that comes with some of them. Get a understrut 10 box and hide the amps in the bose cubby jmo.
Old Jan 15, 2008 | 02:23 AM
StreetOC192's Avatar
StreetOC192
Here's the box for the OE sub location
http://www.wickedcas.com/product.php...1&bestseller=Y
Here's the understrut box
http://cgi.ebay.com/ebaymotors/Nissa...spagenameZWDVW
Old Jan 15, 2008 | 02:50 AM
TheBlackPearlZ's Avatar
TheBlackPearlZ
zenclosures box FTW...
get rid of bose...anything is better then the crap they put in our cars...mostly
jlb
Oct 15, 2017 05:10 AM
bcoffee20
Nov 19, 2015 06:39 PM
Tochigi_236
Sep 27, 2015 03:40 PM
Red G Coupe
Videos
Sep 8, 2015 08:36 AM
