Please help! (trouble w/ Avic D3)
Old 01-21-2008 | 06:30 AM
chris'smax's Avatar
chris'smax
Default Please help! (trouble w/ Avic D3)
I have done the bypass per the directions posted on here but i can't seem to get it to work. I can only play videos or mess w/ my nav when i am stopped, but i don't have to have my parking brake up. What could be the problem. I have a 06 if that makes a difference.
Also i cant play music videos from my ipod either. It will play the sound but not the video on the screen. Does anyone else have this problem?
Old 01-21-2008 | 06:56 AM
clarkemtp's Avatar
clarkemtp
What steps have you done *exactly*, it's hard to diagnose with... "I followed the instructions but it doesn't work". There's plenty of people here glad to help, but we gotta have some place to start.
Old 01-21-2008 | 07:26 AM
IronYuppie's Avatar
IronYuppie
i would assume if you can only hear the sound from the ipod that its the "tv out" setting on the ipod itself. Its in Video Settings. Turn it to on or ask if you like using it by itself sometimes.
Old 01-21-2008 | 07:35 AM
chris'smax's Avatar
chris'smax
Sorry i should have clarified, i used the "how to" directions that were posted in here. I know it is difficult to diagnose this stuff over the internet but i was wondering if maybe other people had issues and how they resolved their issues.
Old 01-21-2008 | 09:17 AM
clarkemtp's Avatar
clarkemtp
Well, my first WAG (wild *** guess) would be since you say the parking brake does NOT have to be set for it to work while the car is in park, you must have successfully grounded the parking brake wire. Soooo....
The second part of the bypass you have to complete is moving the yellow "mute" wire in the D3 harness. Did you do that? Have you checked it to make sure it's in the new spot in the harness good, i.e. the pin is making contact?
Old 01-21-2008 | 10:48 AM
chris'smax's Avatar
chris'smax
yes i moved the mute wire and it seemed to be secured fine, but i will check it again.
Old 01-21-2008 | 10:53 AM
cheshirecat79's Avatar
cheshirecat79
Check your ground and make sure you have the parking brake actually grounded- not all the bolts are grounds on the kit. There's an AVIC install thread that shows which ones are grounds and which aren't.
The ipod thing is most likely a different issue- the ipod touch and iphone can have video out issues based on the firmware they are running. Just make sure tv out is switched on.
Old 01-21-2008 | 11:34 AM
chris'smax's Avatar
chris'smax
thanks for all the help guys!
I think i may have figured it out. I think i have the mute wire grounded to a location that is not a good ground source. It is labeled ground #3 in the install how to thread. I didn't notice until just now that the op states specificaly that this is not a good grounding point. So maybe that is the issue.
Old 01-21-2008 | 12:00 PM
clarkemtp's Avatar
clarkemtp
There ya go. Ground that mute wire and you should be golden.
FreeBaGeL
03-14-2011 03:59 PM
ntwillie1
11-14-2008 10:51 PM
ckthepilot
02-25-2008 04:49 PM
zzz350zzz
06-08-2007 08:35 AM
G35Couper
05-20-2004 04:06 AM
Quick Reply: Please help! (trouble w/ Avic D3)
