Answer to the restrictive front speaker covers
Old Jun 13, 2008 | 08:43 AM
KManZ's Avatar
KManZ
Originally Posted by fatalus
How do those drilled grills sound btw? Any improvement over the stock one?
+1 Hello, Silverstone-Z, update!
Old Jun 16, 2008 | 06:04 PM
blazed54's Avatar
blazed54
i've done my front in the black speaker cloth method. they look and sound awesome. As mentioned the drilling method is far more difficult and time-consuming. Also, i'm not sure how clean the holes will look. let us know when you finish.
FYI: the front speaker grills do in fact obstruct sound. try take both stock grills out and listen to music, and then put them back in to compare. they sound much better with the grills removed.
Old Jun 20, 2008 | 11:44 AM
fatalus's Avatar
fatalus
I did the drilling on the stock speaker grilles and I can say it was worth it. I used a 1mm drill and although it was pain in the *** to do it, if you are careful and patient enough you can do it without harming the appearance of the grilles. As for the result, although it does not sounds as good as without the grilles, it is a good improvement compared to the stupid restrictive stock grilles!!
Obadabot
Jun 18, 2023 11:31 PM
3vilbunny
Jul 18, 2017 05:10 PM
ablaine
Nov 29, 2016 10:13 AM
samansharif
Sep 25, 2015 12:31 PM
