What will sound better? (pics)
Im fiberglassing a subwoofer box behind the driver seat where the stock bose sub used to be. My question is, which will sound better?
Facing out like this...
at an angel
or completely face down like Nazars boxes
at an angel
it most likely will sound like crap in that sport regardless, due to the bass wave must travel somewhat of distance to your ear, in order to sound good...
My suggestion is just stick to Zenclosure box, in the trunk....
having tried the first nad the third, i can tell you nazars box works best...the automotive enviroment, having a loading plane (solid surface) for hte sub to fire off of works wonders...and in a convertible...the difference is relaly noticable...
same amp, same sub, i first just stock it in a box fiing outward, then tried a downward firing, an honest, dramatic difference in response
b
b
b
b
I want it to be semi show, did it sound horrible facing outwards like that? Or was it just not as crisp, loud, ect
not much rattles, but i also dampened it...
you loose quite a bit out of output and feel of hte bass when you face it outward
b
b
do you have pics of of and how you did it?
thanks
edit: found it https://my350z.com/forum/audio-builds/270231-06-zr-install-done-ceo-style-quite-technical.html
how did you do it? fiberglass? was it one clean unit that slid into the compartment?
Originally Posted by Rowlett
Subs Are Non Directional....It will sound the same no matter wich way you place it... the difference is in the BOX, what it's made from, how much space is in it..If theres Poly-fill...etc
350Z_Al
Oct 29, 2020 07:44 PM
Justin100
Nov 29, 2015 03:58 PM
