JL W7 in the back of my Z ??
Old Feb 7, 2008 | 10:31 AM
Da K00l Aid Man's Avatar
Da K00l Aid Man
Default JL W7 in the back of my Z ??
Ok, here is my setup in my 2003 Z. I am running the Pioneer D3 head unit with my stock Bose system as of now. I am looking to do either an 8" or 10" W7 but have a few questions. I am a total n00b when it comes to car audio, so bear with me.
1. Which would be a better application for overall sound quality, 8" or 10" ?
2. Will either of those fit where my stock Bose sub is right now behind the drivers seat?
3. If questions #2 is yes, would it still be better for sound to put it in some sort of enclosure in the rear of the car ?
4. If #3 is yes, is there a Zenclosure that will fit a W7 in it under the rear strut brace ?
thanks in advance for your help
*puts flame suit on just in case*
Old Feb 7, 2008 | 10:39 AM
350zspl's Avatar
350zspl
how does a gentleman new to car audio come to the decision that JL audio is what you want
Old Feb 7, 2008 | 10:47 AM
Da K00l Aid Man
because I have heard the W7's and have listened to a few other subs, and I like the way the W7 sounds the best. I have listened to the Alpine stuff, Rockford Fosgate, etc. Feel free to suggest something else, I am always open to ideas. I want something in the $400-600 range.
Old Feb 7, 2008 | 10:48 AM
Tac-M's Avatar
Tac-M
how bout 10" w3 ?
works for me....
and wut is up wit JL hatin?
Attached Thumbnails JL W7 in the back of my Z  ??-img_1060.jpg   JL W7 in the back of my Z  ??-img_1093.jpg
Old Feb 7, 2008 | 11:00 AM
doug's Avatar
doug
1) Image Dynamics IDMax 10
2) FI Q 10"
3) Resonant Engineering SE 10
all better value for performance than a w7.. i wouldn't take a JL Sub if you were giving it to me for free
Old Feb 7, 2008 | 11:04 AM
StreetOC192's Avatar
StreetOC192
1. either will work for an sq install. It depends really what music you listen to and how punchy you like your bass. also depends what components you are running.
2. it is NOT suggested to put a sub where the stock bose sub is unless you use the wicked cas box.
3. see #2
4. I believe Zenclosures' understrut box will house a 10w7.
There are a lot of subwoofer options. of course it all comes down to YOUR choice because it is YOUR money and YOUR car.
Old Feb 7, 2008 | 11:05 AM
Da K00l Aid Man
Let me pose one other question. If I was trying to choose something that I could order through Crutchfield (ordering head unit on my Sony Financial card), would the JL be my best bet ?
Old Feb 7, 2008 | 11:06 AM
doug's Avatar
doug
Loose Loose situation.. Crutchfield high markup's..
JL has high mark up's for their performance..
you are better off buying a $250 Image Dynamics IDQ v3 than buying a w7 for $500 from Crutchfield
StreetOC192
Easy Tac-M, put the pieces away
It's not so much 'hatin' as it is realizing that there are better values out there, especially if paying retail for JL equipment. There are independent brands out there that may make (arguably) a better product for less money. That is all.
Old Feb 7, 2008 | 11:07 AM
SuperBlack350z's Avatar
SuperBlack350z
I enjoy my w7 a lot. Sounds good.
Old Feb 7, 2008 | 11:09 AM
doug's Avatar
doug
because buying JL Audio is like going to Red Lobster for a Lobster or Outback for a Steak
Da K00l Aid Man
^^^ is that a 10" or 8" ?
SuperBlack350z
It's a 10"
Old Feb 7, 2008 | 11:10 AM
StreetOC192
From Crutchfield and your concern is SQ?
I have owned and LOVED the Boston G510 sub. you can find them cheaper than through Crutchfield, but this is the one I had:
http://www.crutchfield.com/App/Produ...3&tp=111&avf=N
Old Feb 7, 2008 | 11:43 AM
Da K00l Aid Man
SQ to the extent that I just want to add it on to my head unit purchase. The sub is not a necessity right now, I was just trying to a. do a little research and b. get opinions on the subs.
Also, for those recommending other subs, can you provide me some links so that I can see the specs/looks and everything on the ones you are recommending ?
Old Feb 7, 2008 | 11:54 AM
savvy's Avatar
savvy
I have 10W7 in the trunk. I made my own corner enclosure for it
https://my350z.com/forum/audio-video-and-electronics-diy/250086-diy-fiberglass-sub-box-making.html
I bought mine off ebay brand new for about 300. The sub is fantastic, if you have heard it and like it then go for it.
I would advise against using the stock bose location. At least buy a Zenclosure and a proper amp to run it.
Old Feb 7, 2008 | 11:57 AM
350zspl's Avatar
350zspl
more performance for less money
exactly
Tac-m i am not hatin JL, i just was curios how a stereo noob came to that choice
Old Feb 7, 2008 | 11:58 AM
350zspl's Avatar
350zspl
i go to Morton's for steak delicious
good example
Da K00l Aid Man
^^ honestly, my main choice was from hearing them in several of my friends cars over the years. That and I like the clean look that the sub has.
Old Feb 7, 2008 | 12:04 PM
350zspl's Avatar
350zspl
JL Makes a fine product
no doubt
that is a given
other companies make better products for less bread
other companies make better products for more bread
i try to stray from mainstream companies , that are driven by board meetings , and projected sales #'s
i try to spend my $ with companies were the products are designed, and built by individuals that actually are competiters themselves
FI CAR AUDIO FTMWGDW
