ZEnclosure Box / Subwoofer Issue - TERRIBLE Sound
Old Mar 3, 2008 | 03:05 PM
cdoxp800's Avatar
cdoxp800
Originally Posted by doug
i suggest you get a refund from your dentist for your fillings
Yeaa, Might be a good idea. LOL
Old Mar 4, 2008 | 07:34 AM
VO...'s Avatar
VO...
Administrator
Originally Posted by DVFlyer
I tried T-Nuts once........... once. I'll never do that again. It's too hard (for me) to get them to stay in place and then they are too easily cross-threaded.
The diameter of the hole you drilled for the T-nuts could have been too large. I've only had one T-nut ever strip out on me.
Avoiding cross threading is the same as with any other machine screw. Tighten it first with fingers, then use a ratchet afterwards....
Old Mar 4, 2008 | 07:42 AM
VO...'s Avatar
VO...
Administrator
Originally Posted by PPW_07_Z
Any tips on the installation of those t-nuts?
Here's what I used on mine. You have to purchase the bolts seprately.
http://www.partsexpress.com/pe/showd...umber=081-1084
Here's the basic T-nut kit:
http://www.partsexpress.com/pe/showd...number=260-778
Here's how they work:
https://my350z.com/forum/showpost.ph...&postcount=123
Old Mar 4, 2008 | 10:19 AM
SuperBlack350z's Avatar
SuperBlack350z
Originally Posted by vo7848
It's good to hear you got half of the problem fixed. You might want to switch to a T-nut fastener instead of using wood screws. You can torque those down unbelievably hard.
Keep us updated on the results. It sounds like you have some tweeking to do now. The other day I couldn't figure out why my mids/highs sounded distorted. It turned out I had hit an EQ option on my HU by mistake. After I turned it off, then retuned, it sounds terrific....
Vo FTW again. For some reason, i remembered this post, looked at my headunit and the eq on my HU was on as well. Sounds better now.
Old Mar 4, 2008 | 10:56 AM
VO...'s Avatar
VO...
Administrator
Werd.
Obadabot
Jun 18, 2023 11:31 PM
Justin100
Nov 29, 2015 03:58 PM
350z82
Oct 1, 2015 06:25 PM
samansharif
Sep 25, 2015 12:31 PM
