Replacing the head unit questions
Old Mar 10, 2008 | 05:17 PM
Paintballislife's Avatar
Paintballislife
Default Replacing the head unit questions
have '03 touring and i hate hate hate the stock head unit, but can only afford ot change the head right now. Is this going to be a problem? will it run fine with the stock amp and such?
Old Mar 10, 2008 | 09:01 PM
dirty_215's Avatar
dirty_215
Default Changing Head Unit
When I changed my head unit the only thing that was different was the sound, and I upgraded to a 7 inch touch screen. I didn't have any type of voltage problems until I added the rest of the system, but even that turned out to be a bad amp. You should be just fine changing out the head unit first.
Old Mar 11, 2008 | 01:38 PM
Paintballislife
sweet, some idiot at the stereo store said something about he amp wont work because its this and that and you cant do this cause it will do that. didnt make sense to me. any trouble hooking yours up? did it sound better?
Mine i have noticed sounds great and just as it should with the ignition on, but with the car running sounds like ****.
Old Mar 11, 2008 | 03:09 PM
TreeFiddyZee's Avatar
TreeFiddyZee
Do WHAAAAT!?
I found a Metra harness kit that includes RCA connectors if you want to use the stock amp. I'm not sure how viable this is, but I'm gonna check with Metra.
Old May 11, 2008 | 06:18 PM
Allano's Avatar
Allano
Hi, I am new here. I am planning to change the head unit to Pioner AVH-P6050DVD. Can anyone of you help me in wiring? I found out there are 3 sockets and as follows:-
6-Pin Socket
Grey
Black/Yellow
Purple/Red
Pink
Light Green
Blue
8-Pin Socket
Yellow/Red
Light Green/Red
Blue/Red
Grey/Red
Grey
Blue
Pink
Grey
9-Pin Socket
Orange
White
Red
Green
Green/White
Grey
Pink/Black
Red/Black
Blue/White (Big wire)
Which wire represents the speaker wire (LL, LR, RL, RR)? Do I have to use RCA to connect to the stock amp or directly connect the new head unit high output to the respective wire in the socket?
Thanks.
Old May 11, 2008 | 11:20 PM
Mazinger Z's Avatar
Mazinger Z
I'm going to attempt installing a HU this week. I got the harness for the Bose system and it has RCA's already soldered on.
m_0g
Jun 3, 2021 10:05 AM
bcoffee20
Nov 19, 2015 06:39 PM
Vigman
Nov 17, 2015 04:34 AM
cashmoney03
Sep 27, 2015 05:24 PM
bryanlam199
Sep 24, 2015 04:04 PM
