sub wont fit behind seat bracket
Old Mar 21, 2008 | 03:59 PM
BuRtOnRiDeRx19's Avatar
BuRtOnRiDeRx19
Default sub wont fit behind seat bracket
i have a 10 inch sub and it is too small for the bracket behind the driver seat. i was wondering what subs you guys use for it besides the stock bose sub. i was doing some search but couldnt find much. thanks
Old Mar 21, 2008 | 04:36 PM
IndyZ-man's Avatar
IndyZ-man
Most people I believe don't do a direct replacement of that sub. They remove it and put a new sub in a different location. A stealthy install is then to put the amps in this cubby hole and no one knows they're there.
Old Mar 21, 2008 | 06:20 PM
BuRtOnRiDeRx19
thanks..anybody else know of subs that people put in that work//???
Old Mar 21, 2008 | 06:22 PM
DaytonaRoadster's Avatar
DaytonaRoadster
kicker 10s will fit, i just got one installed in mine, fits in stock location just fine
Old Mar 21, 2008 | 06:29 PM
sintaxeror's Avatar
sintaxeror
I would like to see someone mount a sub in the stock location, and seal the entire area up with something lightweight like expanding foam.
Old Mar 21, 2008 | 07:16 PM
BuRtOnRiDeRx19
thanks do you have the exact model number of it or a link because theres so many diff ones
Old Mar 21, 2008 | 08:03 PM
sintaxeror's Avatar
sintaxeror
measure the hole, and then start looking for subs with similar cutout diameter.. post it here maybe we can help you out.
Old Mar 22, 2008 | 10:13 AM
BuRtOnRiDeRx19
from the inside of the hole to the other side it is 9 1/2 inches.
From one skrew across to the other side is about 10 3/4 inches.
Old Mar 22, 2008 | 11:21 AM
sintaxeror's Avatar
sintaxeror
I wouldnt worry about the mounting holes.. just look for something with a similar cutout diameter and then just drill your own holes.
Old Mar 22, 2008 | 11:30 AM
DaytonaRoadster
Its a kicker CV-R 10 inch
Old Mar 22, 2008 | 03:12 PM
BuRtOnRiDeRx19
sounds good guys thanks
Old Mar 22, 2008 | 05:50 PM
seekndestroy19's Avatar
seekndestroy19
+1 i used to have that sub in the stock location, but i had to make a fiberglass panel to fit over it. Sounded good to after all the stuffing and dynomat
Old Mar 22, 2008 | 05:57 PM
seekndestroy19
ps....i had to make a 10" ring out of mdf for the mounting part
Old Mar 22, 2008 | 10:42 PM
BuRtOnRiDeRx19
looks good. what was the ring for? was the sub too small for the holes. that was my problem
Old Mar 23, 2008 | 06:34 AM
seekndestroy19
yea. the holes for the sub were sitting right on the edge of metal
Old Mar 23, 2008 | 05:53 PM
dmw5678's Avatar
dmw5678
Confirmed -- 10 inch Infinity sub does not fit in stock location -- need custom MDF bracket. The mounting plate was a hair to big.
Old Mar 25, 2008 | 01:56 PM
DaytonaRoadster
yeahi just used carpet adn dynomated around it, getting those bose panel to cover it up and make it clean and stockish
Old Mar 26, 2008 | 09:10 AM
seekndestroy19
yea i think no matter what 10" sub you put in your have to make a mdf ring. i would do that anyway just so it dont rattle the metal bracket as much
3vilbunny
Jul 18, 2017 05:10 PM
350z82
Oct 1, 2015 06:25 PM
