just installed my system - alternator noise!
Old Apr 8, 2008 | 04:02 AM
USF350z's Avatar
USF350z
Default just installed my system - alternator noise!
Ok - So I finished installing the following,
kappa components(front)/kappa coaxials(back), infinity 5-channel, kappa 10", and Avic-D3. Sounds great, but at low volume a have a terrible alternator whine, I can also hear my radio change source, change station, etc. I Ran rca's down drivers side, power and speaker wires down passenger side. The amp is in the cubby behind the driver's seat - where the bose sub is normally at. I did not rewire the speakers, just ran wire from the amp to the factory harness. Anyone have any ideas what this might be? thanks for you input - matt
Old Apr 8, 2008 | 04:04 AM
Sean's Avatar
Sean
first change ground, if you have no luck, you can get ground isolation loops at Radio Shack, they will plug into your RCAs
Old Apr 8, 2008 | 04:15 AM
USF350z's Avatar
USF350z
thanks - I'll give that a try
Old Apr 8, 2008 | 04:16 AM
phreaktor's Avatar
phreaktor
Design Engineer
Where is your ampp grounded and where did you run B+ and RCA cables?
Old Apr 8, 2008 | 04:24 AM
USF350z's Avatar
USF350z
amp is grounded to the chasis, in the cubby towards the center - I removed paint down to bare metal. Battery wire is on pass side, and rca's on driver side
Old Apr 8, 2008 | 04:38 AM
Lsmith9523's Avatar
Lsmith9523
Just a suggestion,,after checking your grounds, connections, ect. ect. I would remove speaker wires from pass. side,,,run those down the center console. That way,,,you have everything seperated. Just my opinion,,That is how installed my set-up and have no "whine" or "alternator noise."
z2envy's Avatar
z2envy
ground isolator loops should do the trick. I had to install them on my car as well to get rid of the noise and it worked.
Old Apr 14, 2008 | 11:17 AM
sparkplug's Avatar
sparkplug
check the ground would be the first thing to do. Then the rca and if still nothingbthen cgeck the head unit. Some times that canbevthe problem or even swap the amps out. Ifnit is the head unit you can ground the rca to the head unit.
Old Apr 14, 2008 | 01:35 PM
USF350z's Avatar
USF350z
Thanks for all the input...I ended up just using the ground loop isolators - did the trick - appreciate it guys
Obadabot
Jun 18, 2023 11:31 PM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
