Tweeter Placement
Old Apr 4, 2011 | 10:35 AM
  #41
kcalvano's Avatar
kcalvano
Originally Posted by ETZ
Almost there... More sanding,sanding & sanding! i going to test fit them tonight then cover them. not bab for my first try.
Looking good man. In for updated pics-whacha going to cover them with?
Old Apr 4, 2011 | 12:30 PM
  #42
ETZ's Avatar
ETZ
Default Tweeter Placement
Thanks... I'm going to cover them in suede, I mite do one tonight if I don't get lazy tonight... I need to finish this part up by Friday I still have a lot more to do.
Hey cdoxp800....Not trying to jack you tread just trying to give a little info to who ever it'll help...
Old Apr 11, 2011 | 08:23 AM
  #43
ETZ's Avatar
ETZ
Done!!!
Covered and installed them Saturday….not perfect, but the flaws are not visible. Now on to the next phase.
Im sure the experts do it different , but this worked for me
Quick break down of what I did.
Took to tweeter with me to Home Depot(For fitment) got some pcv plumbing.
Brought a circular saw drill bit (Diameter of the pcv vavle)
Drilled out the hole on the A-pillar plastic for the pcv. (you may have to drimel a little, but tight fit is good)
I put a little glue on pcv back inside to keep it stable while you put a little bondo around the pcv.
The bondo around the pcv serve as a fill in for the next step it should be a smooth transition from the A-pillar leading up to the pcv like a ramp. (don’t forget to sand, I used 150)
Get a T-Shirt that’s stretchable and stretch(Stretch it tight!) it over the pod area and staple it in the back.
Put 2-3 coats of resin over it
After resin is dry go over it with bondo , let dry, and sand it smooth.
Cover the A-pillar with whatever you’re going to cover it with vinyl or suede(use the 3M adhesive in the green can)
Attached Thumbnails Tweeter Placement-pod1.jpg   Tweeter Placement-pod2.jpg   Tweeter Placement-pod4.jpg   Tweeter Placement-pod5.jpg   Tweeter Placement-pod6.jpg
Old Apr 11, 2011 | 04:20 PM
  #44
Spike100's Avatar
Spike100
^^ Nice work! Thanks for posting the details/instructions.
--Spike
Old Apr 12, 2011 | 03:13 AM
  #45
ETZ's Avatar
ETZ
Thanks Spike, still running wires and got to get the head unit,but it's coming along
Old Apr 16, 2011 | 12:38 PM
  #46
vh5150's Avatar
vh5150
Pillars look great! Nice job. How do you have the tweets firing? Are they on axis or aimed directly at each other?
Old Apr 17, 2011 | 09:57 AM
  #47
ETZ's Avatar
ETZ
Firing at each other..... Question of the day.... What is "on axis"?
Old Apr 17, 2011 | 02:51 PM
  #48
Spike100's Avatar
Spike100
I had the same question. vh5150 will hopefully tell us what he meant when he said: “Are they on axis or aimed directly at each other?”
On-axis and off-axis refer to sound direction. Off-axis is sound coming from the side of the speaker, and on-axis is sound coming mainly from the front of the speaker (there is always sound leaking from the sdes).
I suspect that vh5150 means aiming the speaker at the listener (instead of across the front of the car, and directly at each other) when he refers to “on-axis.”
--Spike
Old Apr 19, 2011 | 06:14 PM
  #49
chaparro78's Avatar
chaparro78
Usually the type of tweeter will dictate if it should be on or off axis. I have my focal tweets off axis. In the process of replacing them with Hertz, will more likely be on axis, need to verify
Old Apr 20, 2011 | 09:17 PM
  #50
vh5150's Avatar
vh5150
Thank you Spike. You are correct.
Old Jun 27, 2011 | 09:55 AM
  #51
phreaktor's Avatar
phreaktor
Design Engineer
I have the CDT ES-620 Gold system. What do you guys suggest? A-pillars or kicks?
Old Jun 27, 2011 | 10:20 AM
  #52
ETZ's Avatar
ETZ
I run this set up and the Imaging is great, and I havent hooked up the sound processor yet.
Old Jun 29, 2011 | 06:19 PM
  #53
phreaktor's Avatar
phreaktor
Design Engineer
What tool did you use to open up the door pods so your Focals would fit? The holes in mine are tiny!
Old Jun 30, 2011 | 06:47 PM
  #54
ETZ's Avatar
ETZ
Default Tweeter placement
I didn't use any tools in just took the stock grills off.
Depravity
Oct 1, 2015 04:49 PM
AngryZ
East Canada
Sep 16, 2015 05:08 PM
EnjukuRacing
Drivetrain
Sep 14, 2015 11:15 AM
KJ-350
Apr 10, 2003 03:09 PM
