350z Stock Speaker Location Fitment Guide
Old Jul 31, 2008 | 05:37 PM
sintaxeror's Avatar
sintaxeror
Ahhh I see where the confusion is.. This guide is for FRONT SPEAKERS ONLY. =)
I recommend doing away with the rear speakers completely... Get your front stage nice and you won't need them.
Old Aug 1, 2008 | 12:37 AM
vap0rxt's Avatar
vap0rxt
I'm a bit new to all this sorry if this is a repeated question.
With the spacer does the door panel still fit correctly? Is there any changes to installation besides the spacer?
Old Aug 1, 2008 | 04:46 AM
sintaxeror's Avatar
sintaxeror
Nope, no other mods necessary. I believe you can go up to 1" pretty safely, but don't quote me on that!
Old Aug 1, 2008 | 05:40 PM
KManZ's Avatar
KManZ
Hey, this thread has perfect timing... I was just remounting my components, and it just happens that the crossover terminals on my Infinity Kappa Perfect 6.1's are pure ****... the screws became unthreaded or something, and wouldn't hold my speaker wire. Plus the crossover is HUGE and wouldn't fit anywhere securely. I am OVER these speakers, so am now in the market for new components that A) Fit in stock location w/ spacer, B) have a smaller crossover C) sound more natural than the Infinitys. I couldn't get them to sound right; plus, I have a new amp which pumps 150W RMS, so I can handle some beefy components now!!!!
Suggestions from the list? What would make the Infinity's sound bad AND be better quality?! Bing? Sintaxeror? Anyone!
Old Aug 1, 2008 | 05:49 PM
sintaxeror's Avatar
sintaxeror
All I can really tell you is that the UP6 crossovers are also ridiculous in size... I did get them into the doors though.
I had to remove the huge block of foam from the door panel.
Old Aug 2, 2008 | 07:40 AM
KManZ's Avatar
KManZ
Yeah man, I had to take out the styrofoam for the Infinity crossover too. That's exactly where I mounted mine at; I tried everything to get them to stick, but it just kept coming loose. Have you figured out a way to get them to stay put?
Old Aug 2, 2008 | 08:02 AM
sintaxeror's Avatar
sintaxeror
I just used 3M molding tape.
Old Aug 3, 2008 | 07:33 AM
KManZ's Avatar
KManZ
Thats what I ended up using as well, though I am not confidant it will stay stuck. It doesn't seem to sit flat enough to stick. Oh well. I might end up mounting them in my kick panels.
Old Aug 3, 2008 | 08:05 AM
sintaxeror's Avatar
sintaxeror
I kind of felt the same way and also thought about mounting in kicks... but I didn't want to drill out more of my factory door connectors to run two wire pairs...
I am going to be in there soon anyhow, maybe I'll make some little fiberglass platforms or something for mounting larger crossovers. I could make molds if others were interested in having a set.
Old Aug 3, 2008 | 10:18 PM
Voboy's Avatar
Voboy
RE AUDIO RE6.5-COMP 6½" 2-WAY RE-Series
Will not fit even with Zenclosure spacers, needed ~1mm more to clear.
Old Aug 13, 2008 | 07:39 AM
sintaxeror's Avatar
sintaxeror
Added Rockford Fosgate Punch P162S
Thanks sssza!
Old Aug 18, 2008 | 03:47 PM
phandango's Avatar
phandango
Phoenix Gold RSD65CS barely fit with 1" Spacers plus extra padding. Also needed to mod the door a little to keep the speakers from touching.
So I would say "No" didnt fit... or "yes" with some cutting and modding.
Old Aug 19, 2008 | 01:39 PM
sintaxeror's Avatar
sintaxeror
apparently the ability to edit our posts has been revoked, so I am unable to add more information at will. I have PM'd a mod to add the Phoenix Gold info, and will do so for information on any other speakers that we get in here. Hopefully this development won't kill the progress of this thread.
edit: thanks phandango, info added!
Also, thanks vo7848 for editing the first post for me!
Old Aug 23, 2008 | 03:25 PM
KManZ's Avatar
KManZ
Polk SR6500's fit if you use the stock speaker as a spacer. Not sure the stock grill will fit if you mount the tweeter in the "comp-axial" arrangement (where the tweeter is mounted coaxially). I will check tomorrow when I finish the install. I am going to be cutting ou the stock grill and covering it with speaker cloth to help improve sound... hopefully it won't bulge out.
Edit, post install: I cut the stock grill (stock sound blocker) out and covered the frame in speaker cloth. And they fit over the Polk SR6500's, even in the "comp-axial" mode with the tweet mounted on the woofer. Also, to get the stock spacer to work, you need to do a tiny bit of shaving along the inside edge, as the baskets of the Polk speakers are fairly wide.
Old Aug 25, 2008 | 11:16 PM
sintaxeror's Avatar
sintaxeror
Polk SR6500 added, thanks KManZ
Old Aug 25, 2008 | 11:32 PM
quakerroatmeal's Avatar
quakerroatmeal
The way they made the speaker grill / fitments of the z is totally retarded.
Old Aug 29, 2008 | 12:14 PM
rjb's Avatar
rjb
Focal 165 V2S (not the slim version) will fit with a tapered/angled spacer. I will be making version 2 this weekend to allow for more space (currently .125") between the surround and the door panel.
Old Oct 1, 2008 | 11:31 AM
  #38
ColoradoClark's Avatar
ColoradoClark
Mods: can we get this stickied?
Old Oct 1, 2008 | 09:04 PM
  #39
HATED1's Avatar
HATED1
+1
Old Jan 6, 2009 | 02:20 PM
  #40
sintaxeror's Avatar
sintaxeror
bump for newcomers who don't know this exists..
