350z Stock Speaker Location Fitment Guide
Old Mar 21, 2010 | 04:56 PM
  #101
Pat Bateman's Avatar
Pat Bateman
Originally Posted by Nipz
Is there any way to get better sound imaging while still using the stock grille?(aka without pods) I'm about to put some Focal 165VRs in my Z and i really would like to get them facing at an upwardsish angle instead of at the floor. I was thinking about trying a zenclosure type spacer but a little thicker mdf and angle one side a bit to get the speaker to aim up slightly. It works in my head but it would all depend on how much space i have between the speaker and the grille. Tilting the speaker slightly would make the front to back distance of the speaker greater so i would need enough space between the grille and the window essentially.
If i'm confusing anyone tell me and i'll draw a picture.
The other option which is slightly the same.. is to get some thicker uneven dowels and cut the ends at a small angle to create an angled seat for the speakers. (again, if confused i'll draw a picture)
The Focal 165VR is a 6.5" speaker with a installation diameter of 5.55" and a mounting depth of 2.20" if anyone is craftier than me and can figure this out.
Any updates on your install?
Old Mar 22, 2010 | 02:48 AM
  #102
TomCat0197's Avatar
TomCat0197
Morel Dotech Ovation 6 components fit with a mdf spacer, I'll see if I can get a measurement on the spacer depth.
Old Mar 22, 2010 | 06:13 AM
  #103
Nazar's Avatar
Nazar
Just because it fits there does not mean it will sound good. You are still dealing with the issue of stock grille defusing half the sound. It not only blocks it but the sund wave bounces against the blocked section. Will you be able to make good sound? Maybe. However i still guarantee with pods your sound will be twice as good.
Old Mar 22, 2010 | 01:00 PM
  #104
duro78's Avatar
duro78
some of this info is incorrect ive seen and installed some of these speakers without any clearance issues with no spacers
Old Mar 25, 2010 | 12:19 PM
  #105
jray8's Avatar
jray8
then post pics
Old Mar 31, 2010 | 05:16 PM
  #106
NISMOhopefull's Avatar
NISMOhopefull
anyone know if the kappa 639I or 629I will fit, they are both 6.5"s and the perfects fit so I am guessing they will. just wondering
Old Jun 7, 2010 | 12:10 PM
  #107
lowcel's Avatar
lowcel
I would like to add Alpine SPR-17S (Type R 6 3/4" components) to the list. I used a 1" spacer on the driver and the tweeter fit in the factory location.
Old Jun 7, 2010 | 03:33 PM
  #108
zakmartin's Avatar
zakmartin
I did the same thing with my JL tweets at the factory location. I mounted them just like the Clarion tweets that came with the Bose system. The end result was that they sounded like absolute a$$ mounted behind the factory grills. I re-mounted them in the same spot by drilling out the trim and mounting the tweets in the cups that came with the speakers. This made them a) directional and b) 1,000,000% better sound-wise.
Old Jun 7, 2010 | 03:39 PM
  #109
revvenue's Avatar
revvenue
Infinity Kappa Perfect 6.1 fits with stock speaker ring by shaving a plastic fin off of the inside of the door panel.
The Infinity Perfect 6.1 tweeters are a perfect fit for sail inside or flush-mounting by using a 1.5" drill bit for flush-mounting.
I've also had Diamond Audio HEX S600 and they also fit perfectly with the same setup. The crossover is in the door panel as seen below (before completely touching up the install -- diamond crossovers fit in the same spot)
I used the stock molex for wiring to the speakers.
Old Jun 24, 2010 | 10:46 AM
  #110
sintaxeror's Avatar
sintaxeror
Added Alpine SPR-17S (Type R 6 3/4" components) and another Perfect 6.1 entry. Thanks guys!
Old Jun 27, 2010 | 01:40 PM
  #111
350Z_Al's Avatar
350Z_Al
Re Audio XXX 6.5" mids DO NOT fit behind stock door panels. Magnet hits the window, if you space the speaker out far enough it is touching the backside of the door panel.
Old Oct 20, 2010 | 06:50 AM
  #112
sintaxeror's Avatar
sintaxeror
Updated with RE Audio 6.5" from al@phatrides
Old Oct 20, 2010 | 08:29 PM
  #113
Pat Bateman
Phoenix Gold RSD65CS components only fit 08 with a 1.25" spacer. I bought the 1" MDF ones on ebay and epoxied a 1/4" sheet of luan, creating a 1.25" spacer. Even with that, some of the plastic on the back of the door panel needs to be trmmed. (06-08 doors are the same I think?)
Old Dec 4, 2010 | 07:41 PM
  #114
Z_enthusiast's Avatar
Z_enthusiast
very helpful thread! i wish i could have found this faster than 30min of searching though. Sticky this! lol
Old Dec 15, 2010 | 12:08 AM
  #115
m0kieZ's Avatar
m0kieZ
very helpful thread thanks all for the effort
Old Jan 7, 2011 | 01:31 PM
  #116
sintaxeror's Avatar
sintaxeror
I just update it.. No idea why it won't get stickied. =)
Old Jan 8, 2011 | 04:06 PM
  #117
NismoZZ's Avatar
NismoZZ
Default Pioneer TSD1720C 6-3/4
Installed some New Pioneer TSD1720C 6-3/4" 260W Component Speaker They fit great and sound great the crossover is also very small compared to the other huge crossovers all the equipment looked so nice i decided to show it off will post pics later. Speakers fit with the blose speaker destroyed or with spacer that pioneer includes inthe box with the speakers and also an 6by9 spacer is also included.
Old May 3, 2011 | 04:26 PM
  #118
v-rath's Avatar
v-rath
Angry oops.
Ok, I ordered a jl360.2 amp, door pods and Alpine SPR-13S components. My goof. They are 5.25. I meant to buy the 17s which are 6.5. I pretty much need to send these back I think.
Anyone agree with me? Now that I am sending them back...I wonder if I should just upgrade to a better quality of speaker (which to my noob *** just means more expensive) since I have recovered from spending the 2k on everything else. Or will 17s's sound ok with a 13tw5 on a jl500/1v2...I dunno.
Long story short, should I send the 5.25 speakers back or fit them somehow??
Old May 4, 2011 | 05:43 AM
  #119
Nazar's Avatar
Nazar
Send everything back, buy it all fromme... J/K Ok maybe not.... LOL
But yes, you want 6.5" speakers.
Old Jun 3, 2011 | 02:16 PM
  #120
BTarb24's Avatar
BTarb24
Default A simple answer
It seems like all you need to do is check the Top Mounting Depth to see if it will fit. I think we've collected enough data to say that anything greater than 2.63" (67mm) will not fit. Anything above 2.60" (66mm) should raise concern as these people stated it was a tight fit or had to do some shaving.
Here's some of the research:
Successful:
2.12" Diamond Audio S600S
2.20" Focal 165 VRS
2.32" Alpine SPR-17S
2.38" Boston Acoustic Pro 6.5
2.44" Rainbow SLC 265.25 NG
2.48" DLS UP6i
2.50" Pioneer TS-D720C
2.56" Polk SR6500
2.60" RF Punch P162S
2.62" Infinity Kappa Perfect 6.1
2.62" Polk MM 6501
2.63" Hertz HSK-163
Failures:
2.64" DLS MS6A
2.75" RE AUDIO RE6.5-COMP
2.87" Phoenix Gold RSD65CS
3.03" Focal 165 K2P
3.87" RE Audio XXX 6.5"
BEBO'S ZEE
Jun 7, 2016 07:48 AM
bcoffee20
Nov 19, 2015 06:39 PM
DarkCreep
Oct 17, 2015 11:50 PM
hardkicks
Sep 20, 2015 12:28 PM
