What size amp!
Old May 20, 2008 | 09:23 PM
cyberkline's Avatar
cyberkline
Default What size amp!
I am putting in a kenwood double din nav/cd player with two 10in subs, what size amp will i need? Thanks
Old May 20, 2008 | 09:29 PM
TheOtherRob's Avatar
TheOtherRob
You need to be alot more specific. Such as:
What is the RMS wattage of the subs
Are they dual voice coil? If so 2ohm, 4ohm...
Old May 20, 2008 | 09:30 PM
hmracing350z's Avatar
hmracing350z
u didnt tell what brand name and stage they are so take the subs out of the box, turn the subs over and on the back of the coil it should tell u the max watts on them
Old May 20, 2008 | 09:46 PM
cbr900son's Avatar
cbr900son
+1
Old May 20, 2008 | 09:54 PM
cyberkline's Avatar
cyberkline
at work... but they are jl 10w6v2's i believe....
Old May 20, 2008 | 11:46 PM
cbr900son's Avatar
cbr900son
Get more info. We need to know the ohms and be sure of the model and brand.
Old May 21, 2008 | 04:20 AM
StreetOC192's Avatar
StreetOC192
Since when does size matter? I've seen some small amps that put out a lot of power, and I've seen huge amps that barely put out 50 watts x 2.
Seriously thought, I know you are asking what power rating do you need.....
If you truly do have a JL 10W6v2, then it's a dual 4ohm voice coil driver and according to JL Audio's website, the optimum rms handling of that woofer is 300 watts, but it's "thermal power handling" is 600 watts.
You will want to find an amp that will put out between 300-600 rms into a 2ohm load. I will go to my good old trusty recommendation of a Crossfire VR1000D, rated for 500 rms watts into 2ohms.......:
http://www.woofersetc.com/index.cfm?...Product_ID=165
Old May 21, 2008 | 01:46 PM
cyberkline's Avatar
cyberkline
wow thanks, and that will do for two of them right?
Old May 21, 2008 | 05:23 PM
StreetOC192
Yes
Old May 21, 2008 | 05:55 PM
cyberkline's Avatar
cyberkline
ok i got homw and double checked the subs they are jl 10w3v3.4
Old May 22, 2008 | 02:27 AM
cyberkline's Avatar
cyberkline
^ Does this make a difference?
Old May 22, 2008 | 04:08 AM
StreetOC192
Yes. JL Audio's website will tell you the proper rms wattage recommended for your exact sub.
sales@czp
Sep 23, 2019 03:30 PM
