need help findin the Parking Brake Wire
Just like the title sais. I need help finding the parking brake wire on the Z without removing the center console. Whoever owned the Z before me, installed the head unit wrong, and i want to wire the parking brake wire properly. Anyone know where i can locate it and what the color is???
Originally Posted by TreeFiddyZee
What HU do you have? I grounded the parking brake line on my Kenwood. Didn't bother hooking to the actual car parking brake line.
You might try this (take out spaces)
http://www.r x 8 c lub.com/showthread.php?p=2319442
Originally Posted by seekndestroy19
i believe the drivers side kick panel you can get it. Purple wire (-) trigger
Originally Posted by Coehsp350Z
how certain are you?? i want to make sure i dont mess up anything.
Hope this helps.
Originally Posted by shakuya88
You can always test it. Get a voltage meter, hopfully you or a buddy have one. With the parking break disengaged, poke into said purple wire with the negative (in my exp it usually is purple or purple stripe for parking break) and hole the red to a voltage source in the car. volt meter should read 0. now engage parking break. meter should now read the voltage of the source. most likely 12V.
Hope this helps.
Hope this helps.
i have the pioneer avic Z1. in order for me to view DVDs while driving i have to hookup the parking brake line and then get it reflashed. So i need to know the wire.
Originally Posted by 350zspl
go to avic411.com i think and they can tell you how to dvd bypass easy and quick
Hope this helps.
Hope this helps.
