My New System
Old Jul 14, 2008 | 01:35 PM
Lsmith9523's Avatar
Lsmith9523
enlite,,,Wow,,,I think everything turned out great. I know it must sound awesome. Great Job!!!! Very nice and clean....
Old Jul 14, 2008 | 05:31 PM
doug's Avatar
doug
Originally Posted by Will_Evo
Most amps do...but you usually dont have to change those often enough for installing amps backwards to be a real perk. Just saying...
Priorities
Wires Showing>close dials
Will_Evo
the wires show more through the glass the way you are suggesting... the amp rack sits so low.. you can hardly see the wires.. plus my amps have a blue light that looks really night.. whats tacky is when you open your trunk and the wires are showing.. or you look at the amps from the back glass and you can see wires
Old Jul 14, 2008 | 06:52 PM
CarbonZ08's Avatar
CarbonZ08
yeah just get the %5 tints and you should be abe to see out but not in. That's what I did to mine and my amp and all my stereo system still there!
Old Jul 14, 2008 | 06:56 PM
kenpo_350Z's Avatar
kenpo_350Z
Looks very clean and nice!!
Old Jul 26, 2008 | 01:54 PM
only1's Avatar
only1
Question...
I want the same sub and I am seeing the JL AUDIO 10W3 with dual 4ohm and dual 2ohm. Are they the same or whats the difference?
Old Jul 26, 2008 | 10:24 PM
R-TuneZ's Avatar
R-TuneZ
that is a very clean setup. good work. i love installing systems, though it gets pretty tedious.
Old Jul 28, 2008 | 05:01 AM
350zspl's Avatar
350zspl
5 hours is faster than i can do it
Old Jul 29, 2008 | 12:19 AM
Meatshackle's Avatar
Meatshackle
It wouldn't be wise to install the amps opposite of how he has them. The heat sinks would be on the lower end and the amps would be more prone to overheating.
Old Jul 29, 2008 | 06:34 AM
Will_Evo's Avatar
Will_Evo
Heatsinks dissipate heat not collect it...meaning unless that amp was put in a box with no breathing room ..really doesn't matter what direction it is in . Either way...I still say he needs some type of small cover for the wires...but I also am very picky with stuff like that.
Evo
Old Jul 29, 2008 | 09:52 AM
StreetOC192's Avatar
StreetOC192
Except that the law of physics says "heat rises". Heat rising back into the delicate components that the heat sinks are supposed to pull the heat away from will be detrimental.
Damn physics, screwing with everyone's audio installs!!!
Old Jul 29, 2008 | 11:42 PM
Meatshackle
Ohhhhh......now I get it.
So JL says they do not recommend mounting their amps with the heat sinks down because the wiring will show.
All this time I thought it was because of cooling.
sales@czp
Sep 23, 2019 03:30 PM
Justin100
Nov 29, 2015 03:58 PM
nanotech
Oct 2, 2015 05:02 AM
