speed signal input wire! D3
Old Jul 27, 2008 | 11:52 PM
kyouki350z's Avatar
kyouki350z
Default speed signal input wire! D3
Hey guys im installing my Pioneer D3 tomoarrow i had installed this in my last car and find it to be a easy install, but were im having a problem right now is i cant find were the 08 350z Speed wires are located so i can tap into one of them for the gps and performance part of the d3. i have used the search button on this forums but im not finding anything.
thanks for any help!
Old Jul 28, 2008 | 03:02 AM
ekidd's Avatar
ekidd
try www.avic411.com . when i installed my avic-n1 into my z, from what i remember, its the white wire on the white ac control box behind the shifter panel thingy. Im not 100% sure on this but if someone can confirm it, thatd be great.
Old Jul 28, 2008 | 05:41 AM
Paul350Z's Avatar
Paul350Z
Living in 350Z
Old Jul 28, 2008 | 06:44 AM
bsomthin's Avatar
bsomthin
yeah its the white one on the ac control.. put it in you need it if you dont ur avic will be screwy
Old Jul 28, 2008 | 11:20 AM
kyouki350z's Avatar
kyouki350z
Thanks Guys That is alot of help and sounds easy enofe, and that image is great as well! Im starting the install right now!
Old Jul 28, 2008 | 07:13 PM
kyouki350z's Avatar
kyouki350z
Default done but one more question
So Im done and ill post some pics later, The install was not that bad but man with all the wires the D3 has it got croweded back there almost did not want to lay in right. i also had to redrill some custom holes in the brackets for the beveling kit to sit flush, but all in all looks great now! and i like it!
BUT MY BIG questions is after having my battary off all day then putting it back on i noticed my SERIVCE ENGINE SOON lights has came on and well i never known a car to pop that light when unhooking a battary. do i need to reset it im only at 500 miles on car! help! thanks.
Old Nov 16, 2008 | 03:53 AM
Spoiled Z's Avatar
Spoiled Z
There are 2 grey connectors that plugs behind the A/C controls. I see only 1 white wire on those connectors. Is this the speed sensor?
Old Nov 16, 2008 | 06:42 AM
TRYNALIVEPRO's Avatar
TRYNALIVEPRO
Originally Posted by Paul350Z
would this be the same wire that would be used with Tanabe's TEAS to detect the speed of the vehicle???
Old Jun 12, 2011 | 09:45 PM
gbodey's Avatar
gbodey
Exclamation Please confirm speed signal wire
In following the thread, I see two answers.
1. Is it the white wire in the white connector
2. The white wire on the middle gray connector with silver markings on the wire.
Note: there are actually three white wires on the middle gray connector, one has gray marks, one has a black line and one has a green line.
This is for the 2005 350Z.
Thanks
350Z_Al
Oct 29, 2020 07:44 PM
bcoffee20
Nov 19, 2015 06:39 PM
nanotech
Oct 2, 2015 05:02 AM
Daniel_dh
Sep 7, 2015 12:56 PM
