2 OHM or 4 OHM Sub?
Old Aug 6, 2003 | 06:14 PM
danotto's Avatar
danotto
Default 2 OHM or 4 OHM Sub?
I have a 2 OHM Image Dynamics DVC IDQ V.2 D2 sub. I will be powering it with the rear section of an Eclipse 32440 that claims to be 2 OHM stable. Now, did I make a mistake getting a 2 OHM sub since I am only installing 1 sub? Isn't my only option to wire it 1 OHM? Can this amp handle 1 OHM, or should I just get a 4 OHM sub?
Here are the specs on the amp.
200W x 4 Channel Max. Power Output at 2Stereo
120W x 4 Channel 0.1% THD at 2Stereo, 20-20,000Hz@13.8V (RMS Continuous Power)
85W x 4 Channel 0.1% THD at 4W Stereo, 20-20,000Hz@13.8V (RMS Continuous Power)
ChannelFlex Crossover
Adjustable High-Pass Crossover (12dB/octave, 50 - 200Hz) for Front & 120Hz (Fix) for Rear Independently
Adjustable Low-Pass Crossover (12dB/octave, 50 - 200Hz)
Free-Flow Signal Circuit
Double-Sided PCB
High-Current, High-Speed Output Devices
High-Efficiency, High-Energy MOS FET Power Supply
Audiophile Grade Component Selection
Intelligent 7-Way Discrete Protection Circuitry
Music Reproduction with Low Distortion & Ultra-Low Negative Feedback
Efficient Cooling with Low-Profile Heatsink
Multi-Mode Configuration
Stereo/Mono Switch
2 Stable Design
Old Aug 6, 2003 | 07:09 PM
Apexi350z's Avatar
Apexi350z
Charter Member #50
from the spec, doesn't look like the amp can handel 1ohm stable. You may be able to do it, but it will probably overheat, or not even work.
Why don't you wire the speaker in series, and make it 4ohm? since your amp looks like it support 4ohm.
Old Aug 6, 2003 | 07:11 PM
danotto's Avatar
danotto
That is what I have decided to do. Looks like the amp can only handle 4 ohm in mono anyway.
SKiDaZZLe
Apr 14, 2009 05:22 PM
Stinger1
Dec 17, 2003 05:22 AM
Paul Doerrer
Oct 8, 2003 10:59 PM
Ricky
Nov 28, 2002 12:54 PM
SKiDaZZLe
Oct 2, 2002 08:09 AM
