OEM head unit with aftermaket amp and sub?
Old Aug 6, 2003 | 09:25 PM
supra crazy's Avatar
supra crazy
Default OEM head unit with aftermaket amp and sub?
I was wondering if its possible use a amp and sub with the stock head and if its how would it be done?
Old Aug 6, 2003 | 09:34 PM
Zaph32's Avatar
Zaph32
Yes,
The Infinity Basslink works quite well for this because it has a built in amp that accepts speaker-level inputs.
See my other threads for info on this.
You could wire some other amp from the head unit, but you'd need a speaker->line level converter.
Old Aug 6, 2003 | 09:37 PM
supra crazy
i have an amp already so your saying i have to get a bass link whats that?
Old Aug 6, 2003 | 09:42 PM
Zaph32's Avatar
Zaph32
A basslink is a sub/amp combo from Infinity...but if you already have the amp, you probably don't want that.
Instead, get the speaker level->line level converters (available at any car audio shop or crutchfield) and wire/box up whatever sub you want to throw at it.
In theory, you can run the leads to your amp in parallel from the deck leads like the basslink does, be careful to keep things grounded and isolated though to avoid noise.
Old Aug 6, 2003 | 10:00 PM
supra crazy
speaker level->line level converters how much do those cost?
Old Aug 6, 2003 | 10:21 PM
Zaph32's Avatar
Zaph32
Should be less than $20 apiece.
Old Aug 6, 2003 | 10:31 PM
supra crazy
o ok thanks so what wires do i coneact to the stck head unit?
Old Aug 6, 2003 | 10:42 PM
supra crazy
i look on soundomain.com and crutchfield.com and they all say it wont work for my car i have a track so it doesnt have premium sound will it still work contrairy to what the website tells me?
Old Aug 9, 2003 | 01:33 PM
jnifong's Avatar
jnifong
i've used the speaker->level converters in my eclipse that i had with the stock infinity head and speaker setup. i puled back a small area of insulation on the rear speaker wires and hooked the converters to it. hooked these to my kenwood amp running 2 infinity 10's. sounded real good to me bu then again that factory system wasn't too shabby to start with. way better than the basic one that is in our Z's. I still have my set-up from my eclipse but the box wont fit in the trunk of the Z. once i get a new box made, i plan to hooked it all back up again with the line converters. should work fine.
jon
kyin
Oct 15, 2015 05:54 AM
