alternator
Old Nov 18, 2008 | 03:42 PM
J rad's Avatar
J rad
Default alternator
recommend one?
just got system, and bought a optima yellow top, and i had issues with the amps curring...
SO, the suggested solution after countlessly rewiring it was maybe trying a different altanator.
Old Nov 18, 2008 | 05:03 PM
2006.350ZR's Avatar
2006.350ZR
this should fix you right up my friend...
http://sgpracing-store.stores.yahoo.net/urunpuw35.html
Old Nov 18, 2008 | 05:07 PM
j.arnaldo's Avatar
j.arnaldo
I recommend an alternator.
Old Nov 18, 2008 | 05:28 PM
2006.350ZR's Avatar
2006.350ZR
/\ what he said! you need a high output alt + a big three upgrade on your stock wiring and... a second battery couldnt hurt either.
Kinetik makes some of the best batteries for car audio out there..
http://www.kinetikaudio.com/
do all three together and your problems will be solved!
Old Nov 18, 2008 | 06:11 PM
Kwame's Avatar
Kwame
Originally Posted by j rad
recommend one?
Please list the components of your sound system.
Old Nov 18, 2008 | 08:41 PM
orgasm_donor's Avatar
orgasm_donor
Yup. 110 amps is plenty for most sound systems that generate a max of 1500 watts or so. I would also recommend a Kinetik battery and the big three upgrade for optimum electrical performance. If its still an issue, get an upgraded alternator .
I may just grab that 220 for my car! Thanks for the link!
Old Nov 19, 2008 | 06:48 PM
J rad's Avatar
J rad
i have 2 alpine mrd m1005 amps, pushing two alpine type r 10's.
All together its a little over 2000 watts
kenwood dnx7100
and a optima yellow top battery
4g wiring to the amps. 12 gauge to the rest\
Old Nov 19, 2008 | 08:15 PM
orgasm_donor
Well, thats a fair bit of power but its class D power so its pretty efficient.
Upgrade grounds and alternator wire and see if that helps a bit. If not, upgrade the battery to a Kinetik then the Alternator.
Alternator is always the best upgrade but they are not cheap. I am also sure that 220 amp alt will rob your car of performance too. There is always a sacrifice when it comes to this kind of stuff.
Old Nov 20, 2008 | 06:19 PM
j.arnaldo's Avatar
j.arnaldo
Originally, he had posted "altanator". 'Nuff said!
aarrgghh
May 1, 2022 11:04 AM
derekinthez
South East
Sep 28, 2015 06:35 PM
cashmoney03
Sep 27, 2015 05:24 PM
EnjukuRacing
Sep 11, 2015 08:34 AM
