Fuse keeps blowing in Avic-D3
Old Dec 31, 2008 | 03:23 PM
J350z101's Avatar
J350z101
Default Fuse keeps blowing in Avic-D3
put in the Avic-D3.. 2amp fuse.. everytime i turn it up to high.. it blows.. checked all connections, my other speakers arnt blown, put a new fuse in there.. and same thing happened... anybody have any ideas?
Old Dec 31, 2008 | 04:03 PM
TreeFiddyZee's Avatar
TreeFiddyZee
Do WHAAAAT!?
Better the fuse than your eardrums. If it only blows when it's all the way up, then I wouldn't worry about it. Just don't turn it all the way up.
Old Jan 3, 2009 | 02:39 PM
J350z101's Avatar
J350z101
Er..... No one else has this problem? Or had this problem?? Getting really irritating :{
Old Jan 3, 2009 | 03:31 PM
mattk's Avatar
mattk
Is that really 2A? IIRC it was like a 10A on the back of the head unit...
Old Jan 3, 2009 | 08:21 PM
Chef-J's Avatar
Chef-J
Booooosstt!!
Old Jan 5, 2009 | 09:49 PM
J350z101's Avatar
J350z101
on my fuse box it says 2amp
Old Jan 5, 2009 | 10:54 PM
EVAlonSo's Avatar
EVAlonSo
Nah, almost all aftermarket radios come with 10A fuses. are u talking about the box with a fuse in it that comes attached to the harness on the D3, or your factory fuse box? If its your factory fuse box, slap a 10A in there, 2 amps is not nearly enough.
Old Jan 12, 2009 | 10:59 AM
J350z101's Avatar
J350z101
wow.. lol ok cause it blew again now.. ima go slap a 10A in the fusebox and see what happens ;]
Old Jan 12, 2009 | 11:25 AM
orgasm_donor's Avatar
orgasm_donor
Uh...if the fusebox requires a 2 amp fuse then DO NOT PUT A LARGER VALUE IN THERE! There is a reason why its rated at 2 amps. The wiring may not support that size of fuse so you may see an unwanted fire.
Who installed the deck for you? It is quite possible that they took power from an incorrect source. I would make sure that you have a source that can support that kind of amperage. Straight to the battery is ideal but a 10 amp source from the fusebox should be fine.
Old Jan 12, 2009 | 12:07 PM
mattk's Avatar
mattk
True, never change the correct value. 2A doesn't sound like the correct value on a head unit with built-in amplifier though. Or maybe we all don't understand what power line OP is talking about (which sounds likely).
A 10A fuse on the back of the deck is called out by the Pioneer installation manual -- see page 10. I believe there is also a fuse for the reverse camera, probably not 10A, no idea what it is or should be.
http://www.pioneerelectronics.com/PU.../AVIC-D3?tab=D
Old Jan 12, 2009 | 12:55 PM
WhiskeyHotel's Avatar
WhiskeyHotel
Well, you have to figure that with amp, LCD screen, CD/DVD drive, losses, etc. that 10 Amps sounds a lot more reasonable than 2 Amps. 2 Amps at 12 Volts DC is just 24W.
Old Jan 12, 2009 | 04:17 PM
orgasm_donor
Of course...that is not in contention here. Jamming a higher rated fuse in a lower rated spot can be potentially dangerous. Before doing such a thing, I ask that the OP be sure of what he is doing before something catches on fire. Time to visit an installer me'thinks!
Old Jan 12, 2009 | 04:47 PM
WhiskeyHotel
For sure.
apex locator
Jul 23, 2021 02:27 AM
350Z Project X
Oct 17, 2015 05:16 PM
Beater350z
Sep 9, 2015 03:36 PM
AP350z223
Sep 8, 2015 04:38 PM
