***My Sub just died, need help***
Old Jan 4, 2009 | 09:16 PM
TayTaythatsme04's Avatar
TayTaythatsme04
Default ***My Sub just died, need help***
First off, I know very little about car audio. . .
Was coming back from LA the other day playing the tunes pretty loud and then all of a sudden my sub woofer goes completely silent.
Check the connections on the sub . . . fine, checked the amp and it lights up (audiobahn(I know sucks)) and the fan kicks on but still have no sound from the sub.
Any ideas where to start with this one???
Thanks
T
Old Jan 4, 2009 | 09:49 PM
Chi-TownWarrior's Avatar
Chi-TownWarrior
amp fuses?
Old Jan 4, 2009 | 09:52 PM
shvd64cdy's Avatar
shvd64cdy
start by checking the output going to the sub. disconnect the sub and use a house speaker or another car speaker at a low volume and see if the amps putting any power to the speaker. (i'm assuming you just killed the sub since your amp is still lighting up) replace sub........
Old Jan 5, 2009 | 09:44 AM
adamtaylorpcb's Avatar
adamtaylorpcb
use a multimeter to test the ohm load on the sub... if it is blown then it will read different from what it should.
like a 4ohm sub will read 1.1 ohms if blown or any other variance if its fine them its your amp
Old Jan 5, 2009 | 09:56 AM
Crom's Avatar
Crom
+1 on amp fuses and alternate speaker test...mine did the same thing but there was something internal in the amp that reset itself when I left my bat disconnected overnight..and then I reconnected everything and it was magically fixed....pretty odd.
Old Jan 5, 2009 | 09:36 PM
orgasm_donor's Avatar
orgasm_donor
Remote wire?
Proper ground?
Battery fuse ok? maybe loose?
Subwoofer Tinsel leads ok?
Sub connection inside box ok?
RCA or line level connected ok?
liqalu04
Jan 2, 2022 12:58 PM
bneumann
Oct 7, 2015 12:16 PM
VQA33
Wheels Tires
Sep 8, 2015 08:30 PM
s9am_me
May 22, 2003 08:52 AM
