Impedance and Bridging
Old Jan 28, 2009 | 10:39 PM
xENo's Avatar
xENo
Default Impedance and Bridging
Hi guys, it's been a while since I dealt with a sub setup.
I'm adding 2 10" subs to my ZR with the trunk box ( http://www.zenclosures.com/Nissan_35.../zroadster.htm )
I want to add some decent bass, but I can't remember how the impedance rules go. If I get 2 4ohm subs and bridge them, I need a 2ohm stable amp, right? And if I get 2 2ohm subs and bridge them, I'll need a 1ohm stable amp?
Is bridging still recommended for maximum output?
Here are the subs I'm considering:
Kenwood KFC XW1022D (or the 4+4ohm version...)
http://cgi.ebay.com/Kenwood-KFC-XW10...3%3A1|294%3A50
Kenwood KFC W2511
http://cgi.ebay.com/2-KENWOOD-KFC-W2...3%3A1|294%3A50
Or maybe even this whole package:
http://cgi.ebay.com/KENWOOD-KAC-8104...3%3A1|294%3A50
I'm at a loss on amps. I don't remember the whole peak vs RMS argument anymore...
Recommendations? Thanks in advance!!
Old Jan 28, 2009 | 11:19 PM
adamtaylorpcb's Avatar
adamtaylorpcb
depends how you wire them
2x 4ohm subs can be 2 or 8 ohms
2x 2ohm subs can be 1 or 4 ohms
Old Jan 29, 2009 | 05:26 PM
will4992's Avatar
will4992
First of all, you can't bridge a subwoofer. You can bridge an amp, but only a two channel amp, not a mono amp. You can wire subwoofers in either a series or in parallel depending on voice coil configuration and your desired impedance. Here is a wiring tutorial for dvc subs http://mobile.jlaudio.com/support_pages.php?page_id=161. Also, out of the subs you listed, I would recommend the KFC XW1022D.
Old Jan 29, 2009 | 05:30 PM
will4992's Avatar
will4992
And regarding you amplifier power question, just match the RMS rating of your subs to the RMS rating of the amp and be sure to have your gain set correctly. But, make sure the amp produces that RMS power at the impedance in which you plan to run your subwoofers.
Old Jan 29, 2009 | 08:54 PM
xENo's Avatar
xENo
Awesome. Thank you!
BlinkerFluid
Sep 8, 2015 10:06 AM
perfectlyfrank
Apr 27, 2014 07:53 PM
Stinger1
Dec 17, 2003 05:22 AM
G35Girlie
North East
Aug 23, 2003 08:39 AM
perfectlyfrank
Apr 11, 2003 06:10 AM
