USA SPEC PA11-NIS help
Old Feb 27, 2009 | 02:58 PM
gennosuke1's Avatar
gennosuke1
Default USA SPEC PA11-NIS help
can anyone help with installing this for the car. i searched and only found this link but all that necessary?
http://liljerk.morpheus.net/350Z/dash_removal/
Old Feb 27, 2009 | 04:04 PM
freedonutss's Avatar
freedonutss
Are you stuck or are you wondering if thats all you need to install that item on your car?
Old Feb 27, 2009 | 04:11 PM
KYEXTAZ's Avatar
KYEXTAZ
yes that is what you need to do to install it in the back of the stock radio. mine had the option in the back for satellite radio so it goes through that connection in mine.
Old Feb 28, 2009 | 09:58 AM
gennosuke1's Avatar
gennosuke1
no i am wondering if thats correct, that i have to take the whole center console out
Old Feb 28, 2009 | 12:03 PM
WhiskeyHotel's Avatar
WhiskeyHotel
Yes, you do. Or at least take it out enough to get to the back of the radio.
Old Feb 28, 2009 | 12:24 PM
JEKL's Avatar
JEKL
As you can see from all the images, the radio is mounted to the back of the bezel. So unless your hands are small enough to reach under the white AC control box and then be able to remove the wire harnesses, yes you do need to remove the bezel.
It's 6 screws, don't sweat it. I would be amazed if it takes longer than 90 seconds to have it out.
Old Mar 4, 2009 | 09:52 AM
krazi3m3's Avatar
krazi3m3
No you dont have to take the hole center consol out only the one that goes around the shifter and make your way up from there
Old Mar 4, 2009 | 10:07 AM
WhiskeyHotel
I tried that when I was installing mine. It was much easier to pull the whole thing out just enough so I could see what I was doing.
Old Mar 4, 2009 | 11:21 AM
gennosuke1's Avatar
gennosuke1
yikes more pics any videos?
Old Mar 4, 2009 | 12:08 PM
JEKL's Avatar
JEKL
That is probably why he said it was such a pain to install in another post about the unit! Just take the damn console out.
Genno, you really are not a fan of seaching are you??? Here is a link where the guy spoon feeds it to you:
https://my350z.com/forum/audio-video...y-monitor.html
Old Mar 4, 2009 | 03:19 PM
gennosuke1's Avatar
gennosuke1
^^ thanks i did take a look at that thread before but i thought it was only for the bose system
Depravity
Oct 1, 2015 04:49 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
