NEED HELP WITH AUDIO SOUND or SPEAKERS
Ok, so i have a 2004 Nissan 350z roadster and i started noticing that the speaker in driver side panel would sound from time to time. I really didnt think anything of it until one day all 4 speakers just stopped working. Then i turned up the volume and got nothing, as i was driving i had left the volume up and the sound came back on out of no where. 2 weeks later all 4 speakers stopped working again. its now been 3 weeks. Ive tested all fuses in the fuse box by the clutch pedal. I tried pulling the audio fuse from the engine bay and replacing it and still no sound. My warranty is no longer valid and I tried consulting with NISSAN and they asked me to leave the car for a few days which i cannot do.
Can anyone please help me.
thanks in advance
thanks in advance
if you have the bose system, which i believe you do, you might have a beat amp unless that speaker that was intermittent is grounding out in the door...that could definitly cause the sound outputs to mute...start by checking the original issue...the speaker that cut in and out then go from there...i honestly couldnt tell you how to test the amp since it could be the amp or the outputs from the radio to the amp...i would check the problem speaker first
Justin100
Nov 29, 2015 03:58 PM
