Would running a 1 10w3 be better then 2 of them in a Zenclosure?
Old Mar 6, 2009 | 10:26 AM
eyeSea's Avatar
eyeSea
Default Would running a 1 10w3 be better then 2 of them in a Zenclosure?
I was thinking because there would be more air space inside the box versus having 2 10" W3V2's.
Old Mar 6, 2009 | 12:42 PM
will4992's Avatar
will4992
No, 1 would not be better. When it comes to subwoofers, more air space doesn't mean better. You want to provide the optimum box volume for the particular sub. 2 10w3 would be louder. Their optimum enclosure size is .625 cu ft. so the large zenclosure box would be about right after displacement.
Old Mar 6, 2009 | 01:52 PM
quakerroatmeal's Avatar
quakerroatmeal
It will probably sound better/balanced out, but not going to be insanely loud. Unless you got upgraded front speakers then you would drown out easily on 2x10s.
Old Mar 8, 2009 | 07:36 PM
w8lifter21's Avatar
w8lifter21
Like will4992 said, one will sound better. From experience . I had two of the exact subs in my Z. Sounded ok with the windows up, but when I would crack the windows about 1", and then they would come to life! That's a very clear indication that your enclosure is too small for your subs. If you insist on having two, one thing I did that helped until I bought a different box is to mount the subs inverted. Meaning magnets out. By doing this you are freeing up a little air inside the box that was once displaced by the subs. It was still too small for the subs, but it helped for a little while lol.
apex locator
Jul 23, 2021 02:27 AM
350Z_Al
Oct 29, 2020 07:44 PM
