Help with Power Acoustik cubby install...
Old Mar 7, 2009 | 05:34 PM
surfer05rdr's Avatar
surfer05rdr
Default Help with Power Acoustik cubby install...
hey guys i have a little problem after i installed my power acoustik cubby screen. I have power to the screen and everything turns on but when its turned on it says No Signal. There is a yellow rca cable coming out from behind the screen and i have it plugged into a yellow rca video input cable from the H/U. The H/U is a Pioneer Avic F900BT. I think i have it plugged into the correct spot. I would like to get it where i can run the navigation off the screen and still mess with my radio on the H/U. Can someone instruct me on how do fix it or help me do this. Thanks Guys
Old Mar 7, 2009 | 06:08 PM
Peak350's Avatar
Peak350
You need to connect to the video output cable on the head unit.
I'm not sure if you'll be able to do what you are trying to do, I think you might be stuck with 2 displays of the same thing, but either way please post it here.
I'll look on avic411.com and see if I can find anything helpful and related to this for you.
Old Mar 7, 2009 | 06:41 PM
surfer05rdr
thanks for the help man. I have the rca from the screen plug into the rca coming out of the H/U. However i dont think there is a video output wire coming from the back of the H/U. Only one i could find was a video input but i will look again
Old Mar 7, 2009 | 06:49 PM
Peak350's Avatar
Peak350
The pioneer site says it has a composite video output.
Its been a while since I've had my unit out so I don't remember, but it makes sense there is an output if for nothing other than rear seat monitors.
http://www.pioneerelectronics.com/PU...C-F900BT?tab=B
Edit - and I found nothing in a preliminary search of avic411, although I was able to find some more things I can do to my 700bt to steal features from the 900
Old Mar 7, 2009 | 06:57 PM
surfer05rdr
So noone knows of a way i could show the nav on the cubby screen while at the same time mess with the cd/radio on the H/U
Old Mar 7, 2009 | 07:11 PM
Peak350's Avatar
Peak350
I'm not saying it isn't possible. the only thing I have with an RCA input is my 42" TV thats in my house, so I can't really test this with a secondary screen.
Old Mar 7, 2009 | 07:31 PM
MadZkill's Avatar
MadZkill
From what I seen on avic411, You can only watch video on the second monitor.
Old Mar 7, 2009 | 07:34 PM
surfer05rdr
thanks for the help man here is a pic of the install
Old Mar 7, 2009 | 07:47 PM
MadZkill's Avatar
MadZkill
http://www.avic411.com/forum/viewtopic.php?t=21624
Old Mar 7, 2009 | 08:14 PM
surfer05rdr
well i think that just said i cant run two different audios. im not worried about that i just want the nav on the cubby screen and the radio on the H/U. Or can anyone at least tell me how to get signal to the cubby screen
Old Mar 7, 2009 | 08:47 PM
Peak350's Avatar
Peak350
well i think that just said i can run two different audios. im not worried about that i just want the nav on the cubby screen and the radio on the H/U. Or can anyone at least tell me how to get signal to the cubby screen
There is a video out cable, connect to it. You are connected to a video in cable, that won't work.
Old Mar 8, 2009 | 08:23 PM
surfer05rdr
i checked the wires that are coming out of the pioneer headunit and i didnt see any video out cables here are they only cables that are coming out of the headunit
suberwoofer output (red, white)
rear output (red, white)
front ouput (red, white)
audio input (red, whit)
rear view camera in (brown)
Video input (yellow)
Rear Monitor Output (yellow)
i have tried to hook up the power acoustik monitor to all these an the screen still says no signal. Does anyone know why????
Old Mar 8, 2009 | 09:55 PM
HipHopPro's Avatar
HipHopPro
This is the hook up for all extra monitor's, I think, my hook up, Clarion MAX675VDII H/U video out to "FARENHEIT 1 IN 4 OUT VIDEO SIGNAL BOOSTER" (box) to Monitor (I only have one monitor in the back for my son, G35 Coupe). Do you have one of these box hooked up? Hope that helps.
Attached Thumbnails Help with Power Acoustik cubby install...-farenheit-1-in-4-out-video-signal-booster.jpg
Old Mar 8, 2009 | 09:59 PM
surfer05rdr
no i dont have one of those. I bought the screen used from a member on here and i only got the screen and a remote. I never even seen one of those box. If i need one where could i get one and how much do they cost
Old Mar 8, 2009 | 10:07 PM
HipHopPro's Avatar
HipHopPro
You can get anyone. Mine was about $13.00
http://www.sonicelectronix.com/cat_i...mplifiers.html
Old Mar 8, 2009 | 10:08 PM
CAVZ33's Avatar
CAVZ33
For my setup you did not need that box, I had it hook up to Kenwood DNX7100. The monitor does not come with that box and I don't think you need it. Have you tried switching to AUX? I read that you can have video on the screen and nav on the HU with the F900BT but that's it. Try searching for the answer on avic411. I read of people playing video on a screen but it does not say how its hooked up.
Old Mar 9, 2009 | 08:13 AM
surfer05rdr
yeah i have tried the AUX i just cant get no picture to the screen. I dont know what to do
Old Mar 9, 2009 | 08:49 AM
CAVZ33's Avatar
CAVZ33
http://www.avic411.com/forum/viewtopic.php?t=16707
Old Mar 9, 2009 | 09:39 AM
Peak350's Avatar
Peak350
Rear monitor out is video out.
Old Mar 9, 2009 | 09:52 AM
surfer05rdr
ive have tried hooking up to that one an cant get it to work
