Need good 200w x 2 AMP
Old Mar 12, 2009 | 10:00 PM
seank426's Avatar
seank426
Default Need good 200w x 2 AMP
I'm looking for a good amp that can power around 200w x 2 at 4ohm. I was originally looking at the JL 300/2v2 ($290) was than recommended Fosgate P400-4 ($170) but have heard not such good things about Fosgate from A LOT of people. Any suggestions? Btw I am on a budget so I would like to spend know more than ~$250.
Sean
Old Mar 12, 2009 | 11:42 PM
uhtjoogoorih's Avatar
uhtjoogoorih
i think you'll be happy with the Elemental Design NINe.2X. regular price is $250 but sale price right now is $150. I'm using it right now for my comps up front and got nothing bad to say about it. you should look into it. they get only good positive reviews. haven't really come across a bad review yet. here's the link http://www.edesignaudio.com/product_...products_id=47
Old Mar 13, 2009 | 07:39 AM
seank426's Avatar
seank426
that thing looks HUGE though
Old Mar 13, 2009 | 07:42 AM
blasian's Avatar
blasian
It's slightly bigger than my nine.1 which to me isn't that big of an amp.
Old Mar 13, 2009 | 07:48 AM
seank426's Avatar
seank426
Would this fit behind drivers seat in stock Bose compartment though?
Old Mar 13, 2009 | 06:21 PM
uhtjoogoorih
oo...in the compartment it might be a tight fit. if you can get the measurements for the compartment you should be able to see since the dimensions are given on the website. I use both the nine.2x and nine.1 and they aren't small by any means but aren't TOO big. the amp is little under 17" so if you can fit roughtly 19" into the compartment you should be fine.
Old Mar 13, 2009 | 06:27 PM
seank426's Avatar
seank426
something I never understood that maybe someone can help explain. I will be getting a JL 10w6v2 which is dual 4 ohm but I have read you have wire it to different ohms. What would the difference be between setting it at different ohms and would a NINe.1 be a good fit with a JL 10w6v2?
Old Mar 13, 2009 | 07:08 PM
uhtjoogoorih
just wondering, what is going to be powered by the 2x200 amp? and the nine.1 would be pretty good choice i think. never really dealt with JL subs so can't really say much about it.
Old Mar 13, 2009 | 07:19 PM
seank426's Avatar
seank426
Not totally set in stone but as of now most likely a set of Hybrid Clarus C61-2's.
Old Mar 14, 2009 | 04:54 PM
Peak350's Avatar
Peak350
A 10W6v2 with dual 4 ohm voicecoils can be powered in 3 ways (as far as ratings go).
The best two options for you are a single channel amp driving both voicecoils (in parallel) giving you effectively a 2 ohm single voice coil (as the amp sees it), or to drive each voicecoil from a separate channel on the amp (feed mono signal from head unit), and then have 2x 4 ohm voice coils.
Old Mar 14, 2009 | 08:12 PM
seank426's Avatar
seank426
So the Elemental Designs NINe.1 would be plenty, actually more than enough. They are rated at 450w x 1 @ 4 ohms and 900w x 1 @ 2 ohm. Correct?
Old Mar 15, 2009 | 07:22 AM
Peak350's Avatar
Peak350
The nine.1 would be overkill for a single 10w6, I'd personally look for something that cost less (me being cheap).
Jambo016
Sep 16, 2016 01:08 PM
