W7 issue
Old Mar 21, 2009 | 11:33 AM
  #41
adamtaylorpcb's Avatar
adamtaylorpcb
yeah you can, i was just lazy
works good... got much louder and cleaner
rattle trap is the 80mil fatmat. i did allot of the inside also, seemed to work pretty well.
im actually selling the box now since i made a larger one
Old Mar 22, 2009 | 09:07 PM
  #42
harvin350z's Avatar
harvin350z
Iam planning on porting it also, I will let you know.... thanks for all your help.
Old Mar 23, 2009 | 01:11 PM
  #43
adamtaylorpcb
it will be much easier to use pvc tubes... just so you know
Old Mar 27, 2009 | 06:43 PM
  #44
Panda_stunter's Avatar
Panda_stunter
thats weird since i have 13w7 on my z. you just got to have the right kind of box.
heres my set up...
Old Mar 28, 2009 | 10:49 AM
  #45
adamtaylorpcb
Overkill much?
Old Mar 28, 2009 | 02:43 PM
  #46
Panda_stunter
no not really.
i almost went with 2 13w7! haha!
it sounds so clean in my car, its not ported and no fatmats. the box is just per specs needed for it.
Old Mar 31, 2009 | 04:13 PM
  #47
Panda_stunter
i just read the whole thread and i believe your problem is improper fitment of the sub, the zencolsure does not have enough cubic air space in it so porting it is the best solution.
see, when you port a box, it makes the same sound as a bigger sealed box since there is no trapped air in the box. the ports freely moves it. and the reason to ave a bigger box if its sealed is not only for tuning but also for heat dissipation. if the zenclosure has enough cubic airspace (which it doesnt) this could be avoided. but low cubic air space means less heat dissipation leading to hot coils, then it leads to hot base which degrades the foam surround.
if you look at my setup. you can tell the depth of the box. the lower half (where the sub is located, or after the tower bar) 3/8th of that space is for the box.
you said you have 500/1 jl amp. yes thats the recommended amp....for rms. but the peak output is well over that range. since jl's 500/1 amp can put out more than 750 on peak outputs.
that and the 10w7 has foam surround. i have rubbers! =)
ill try to get more pics for you! if i find some from my friend who built the box
Old Mar 31, 2009 | 05:12 PM
  #48
adamtaylorpcb
750 is still fine on the 10 w7, i know people who run the hd750 no problem...... i wouldnt do it but yeah
Old Apr 1, 2009 | 12:14 PM
  #49
Panda_stunter
true...hmmmm...
then another thing you have to look out for are spikes. your best bet is get a cap. it also doubles as a voltage regulator since it wont let spikes go through it.
another thing i didnt ask...for that setup, what gauge wiring are you using? bigger gauge wires will let spikes though, that could also be the reason youre ripping.
Old Apr 1, 2009 | 04:42 PM
  #50
adamtaylorpcb
im using 8 gauge as my speaker wire and all is fine
Old Apr 2, 2009 | 12:23 PM
  #51
will4992's Avatar
will4992
I don't know where the idea that the zenclosure box is too small is coming from. The zenclosure box is 1.4 cu ft. sealed before displacement. JL recommends 1.25 cu ft for a sealed box for a 10w7 (http://mobile.jlaudio.com/products_s...hp?series_id=5). So obviously the enclosure is not too small.
Old Apr 2, 2009 | 01:06 PM
  #52
adamtaylorpcb
mine sounded odd in the zenclosure, thats why i ported it
Old Apr 3, 2009 | 03:41 PM
  #53
harvin350z's Avatar
harvin350z
Thanks for all the comments everyone....iam gona try the alpine type x in the same box and see how it sounds. I think it is a much stronger sub and is built well. I will posts some pics next week and let you know how it sounds. iam also gona be using the 1000/1 with it. Thanks!
apex locator
Jul 23, 2021 02:27 AM
sherm
Apr 11, 2020 05:21 PM
350z82
Oct 1, 2015 06:25 PM
Depravity
Oct 1, 2015 04:49 PM
