The absolute "loudest" components... At least 200w RMS power handling.
Old Mar 18, 2009 | 12:53 PM
phreaktor's Avatar
phreaktor
Design Engineer
Smile The absolute "loudest" components... At least 200w RMS power handling.
I've been through entry level Focals and Infinity. I just can seem to get enough front stage to balance out with my two RF P3 12s. Any reccomendations? Looking to spend $500.00.
Old Mar 18, 2009 | 01:04 PM
SuperBlack350z's Avatar
SuperBlack350z
have you tried adjusting the speaker/subwoofer output to balance things out?
Old Mar 18, 2009 | 01:08 PM
michaeljr6's Avatar
michaeljr6
for only 500........i can't help you
Old Mar 18, 2009 | 01:41 PM
Spork's Avatar
Spork
What do you mean by "loud"?
Bass? Clear highs? Balance of both? Are your doors sound-deadened/matted?
If you're trying to balance out two 12" P3's... have you tried lowering the bass going to the fronts so more highs can come through at higher volumes without the woofers getting overdriven?
Old Mar 18, 2009 | 02:30 PM
phreaktor's Avatar
phreaktor
Design Engineer
Yes the setup is properly tuned (aside from this)and the doors are soundproofed. I dont want to settle forr reducing tue gain to the subs. They are meant to pound. By loud mean SPL in tye mid range. Im thinking I may need to add a set of coaxials up front with the components in the kick panels.
Old Mar 18, 2009 | 02:54 PM
doug's Avatar
doug
http://www.woofersetc.com/index.cfm?...roduct_ID=4928 <--- 150w RMS
http://www.woofersetc.com/index.cfm?...roduct_ID=7080 <--- 160w RMS... 300 Peak
http://www.woofersetc.com/index.cfm?...roduct_ID=7183 <--- 200w RMS ... 300 Peak
Old Mar 18, 2009 | 05:34 PM
adamtaylorpcb's Avatar
adamtaylorpcb
H.A.T. LEGATIA L831-3 PRO
but a little over double your budget
about 800-1000 rms
run on active
Old Mar 19, 2009 | 01:37 PM
folgrz's Avatar
folgrz
how about some RE audio XXX components?
Old Mar 19, 2009 | 03:14 PM
orgasm_donor's Avatar
orgasm_donor
You never mentioned the power that will run these components. If you run 75 watts X2 then I highly doubt you will get 'loud' and still have a nice, distortionless sound coming out of them.
Oh, and you said 'loud in the mid range SPL'. That doesn't make much sense as SPL is rarely evident through speakers that play 80 hertz and up efficiently.
Old Mar 19, 2009 | 04:00 PM
adamtaylorpcb
^^^^^^^ thats the truth..
db's come from those but spl is Sound Pressure Level
hope your not expecting a pair of 6" speakers to give you that
AbrasiveRaysive
Sep 20, 2021 02:29 PM
350Z_Al
Oct 29, 2020 07:44 PM
3vilbunny
Jul 18, 2017 05:10 PM
