Speaker install
Old Apr 3, 2009 | 02:49 PM
BlueZ33's Avatar
BlueZ33
Default Speaker install
first ill start off with what im putting in: im installing infinity reference components up front and i recently got ahold of some infinity 2 ways and i decided to put them in the rear. my original plan was to just run the door components off of my jl audio 300/4 on 2 channels.but since i have these other infinity 2 ways, my question is how should i wire the 2 rear speakers; with the factory wiring or connect them into the wiring that is going from the amp to the crossovers.
thanks for any input
Old Apr 3, 2009 | 04:20 PM
Spike100's Avatar
Spike100
If you really want rears, I think you should connect the rears to your external amp, and run this in 4 channel mode.
But... Do you have SubW's?
--Spike
Old Apr 3, 2009 | 04:27 PM
BlueZ33's Avatar
BlueZ33
yeah i have 2 jl 10w3v3-4's inside of a jl stealth box that i will be adding
but my question is would it sound ok even if i dont have a crossover for the 3rd and 4th channel on the rears
Old Apr 3, 2009 | 04:40 PM
Spike100's Avatar
Spike100
^^ I'm confused?
You don't have crossovers for your rear component speakers?
Sorry if I'm wasting time here.
--Spike
Old Apr 3, 2009 | 04:43 PM
BlueZ33's Avatar
BlueZ33
yeah i never bought a set of components for the rear i was only going to do a front stage setup and now ive decided to install these
Old Apr 3, 2009 | 05:05 PM
Spike100's Avatar
Spike100
OK… I get it.
Since the stock OEM rears are coaxials, and you are installing two-way components in the rear, you will need to do some additional wiring. That’s easy. Of course, you connect your new rears directly to your aftermarket external amp.
--Spike
3vilbunny
Jul 18, 2017 05:10 PM
