Question about all new setup
Old Apr 6, 2009 | 04:16 PM
tannerday's Avatar
tannerday
Default Question about all new setup
I've done some research and still cant figure out what's best bang for my buck for new audio for the z. I want new speakers, sub, amp, any deck or display that can use and charge my ipod. I am on a tight budget though, what's some good quality things i could get? Links would be awesome. Thanks so much.
Old Apr 6, 2009 | 04:22 PM
ohfourzee's Avatar
ohfourzee
whats your budget? Do you want fronts and rears? Do you want coaxials, or components? There are many options. Give us some more information to work with.
Old Apr 6, 2009 | 04:30 PM
Spork's Avatar
Spork
Need to know your exact budget.
Old Apr 6, 2009 | 04:41 PM
tannerday's Avatar
tannerday
Sorry, Budget for everything is about 600-700 dollars. What are best speakers for the 350z? That will fit and i can just order so i can have those atleast.. maybe i dont need sub and amp maybe just head unit for ipod and nice speakers. Do i need a new amp to make new nice speakers work? Sorry im retarded when it comes to car audio.
Old Apr 6, 2009 | 05:08 PM
ohfourzee's Avatar
ohfourzee
Search, and then ask.
Old Apr 6, 2009 | 05:46 PM
Spike100's Avatar
Spike100
$600 is a modest budget, but that amount does allow a decent CES if it’s mostly sound you are after (no GPS or video).
Do this for the tear-down:
  • Remove the cheap OEM H/U.
  • Remove the front OEM component speakers (you will be replacing these)
  • Disconnect the rear speakers (they are cheap and only compromise your sound; and you don’t need them).
Do this for the build-up:
  • Install a good Single-Din H/U (SD H/U’s are a great value; you can get a good one for $150-$200).
  • Buy an intermediately priced 4 channel external amplifier (you can get this for about $200). You want a 4 channel so that you can accommodate your SubW that you add later.
  • Get a high-end coaxial speaker (that will cost $150-$200) or a low-end component speaker (about the same cost, but still sounds good). Your budget demands a stock door mount, so that’s where you put the speakers.
At this point, you are at your budget, but you will have very decent sound in your car (but sans a SuBW). Start saving $$ for a SubW (that you connect with the 3rd and 4th channel available on your 4 channel external amp).
Hopes this helps,
--Spike
Old Apr 7, 2009 | 09:38 AM
tannerday's Avatar
tannerday
Hopes this helps,
--Spike
Very Helpful! Thanks a bunch. I want to buy the audio stuff on ebay. What should i be searching for? Size of speakers? What kind of amp? How many watts for the amp. Specifics help a bunch. Thanks tho for what you have done already.
Old Apr 7, 2009 | 11:36 AM
nawgee's Avatar
nawgee
6.5s for speaker sizes, depending on the type of speaker you get you can choose the appropriate amp to run them.
350Z_Al
Oct 29, 2020 07:44 PM
issyz
Jul 2, 2017 03:04 PM
