Power Acoustik pt700 MHR screen
Old Apr 20, 2009 | 01:26 PM
ohfourzee's Avatar
ohfourzee
Default Power Acoustik pt700 MHR screen
I just got this screen to put in my cubby. However, I have one question. When I took it out of the box, I saw it only had one YELLOW RCA. The other wires are black and red and are to be connected to DC 12V. Whats the best way to do this?
Old Apr 20, 2009 | 06:13 PM
Spike100's Avatar
Spike100
Connections for your Power Acoustik pt700 MHR:
  • Black wire to ground.
  • Red wire to 12v power source (ACC line).
  • Yellow wire to a composite video feed.
Make sure you connect the red wire to an ignition switchable ACC power source. The Power Acoustik pt700 MHR supports an always-on sleep feature so that you can use the remote to turn the monitor on or off. If you connect the monitor to a direct power line, it will drain your battery when the car is off and the monitor appears to be off (i.e., the monitor is never off unless it has no power).
--Spike
sales@czp
Sep 23, 2019 03:30 PM
codek
Sep 28, 2015 03:03 AM
Tochigi_236
Sep 27, 2015 03:40 PM
