Bridging two inputs in to one 3way speaker
Old May 3, 2009 | 06:08 PM
Kiriller's Avatar
Kiriller
Default Bridging two inputs in to one 3way speaker
Hey question here, today i have replaced the stock sh1tty speakers in the doors, made a HUGE difference towards the kind of sound the car outputted with a stock deck. Now the question is, because these are 3 way speakers, and i already have good tweeters on the speakers (kenwoods) is it possible to disconnect the stock tweeters, take those wires from tweeters, and hook them up to already powered 3way speakers to sort of double the power inputed into the speaker?
Hopefully I explained my self so everyone could understand, please let me know if this is possible, thanks!
In short; disconnect stock tweeters, use those wires and the wires going into door speakers, connect them both to the front door speakers to double the power.
Kenwood KFC-S1782 250w 3-way Speaker
Old May 5, 2009 | 06:35 PM
Kiriller's Avatar
Kiriller
Bump? :]
Old May 5, 2009 | 07:28 PM
Spike100's Avatar
Spike100
Questions:
  1. Do you have the OEM Clarion H/U or the OEM Bose?
  2. Do you have an aftermarket external amp?
  3. Where are you mounting the aftermarket tweeters (Are the tweeters inside the 3 way speaker or are they remote)?
--Spike
Old May 5, 2009 | 09:02 PM
Not sure is this is a good idea:
a. Power to the tweeters may be AFTER a crossover.
b. Tweeters and EOM door speakers may be powered by 2 amplifiers. Impedance is matched to insure proper operation. If the amplifier is NOT designed for this type of bridging it may cause amplifier problems.
Old May 5, 2009 | 09:29 PM
Spork's Avatar
Spork
The tweeter mounted on the x-Way speakers is usually after a crossover of some sorts or resistors. Like davidv said, it may also contribute to the speaker's impedance rating. Just leave it alone.
Old May 6, 2009 | 04:30 AM
Kiriller's Avatar
Kiriller
Sounds good fellas, thank you for the input. and just to clarify; i have OEM Base HU. stock tweets in pilars, 3way kenwoods in doors, everything else stock.
Old May 6, 2009 | 05:14 PM
Door speaker and tweeter are powered by same output. Leave the tweeter terminals DISCONNECTED. Tape connectors so they do NOT touch metal.
Old May 6, 2009 | 07:57 PM
Kiriller's Avatar
Kiriller
Thank you very much for the info, another question though, seeing how the door speakers (oem) are 40watts peak, this probably means that the signal is roughly 40~watts peak, and unplugging the stock tweeters, will make the signal roughly 2x (80watts peak?) any idea on the power ratings that are outputted from the stock amp? thank you!
Old May 7, 2009 | 08:56 AM
dryseals's Avatar
dryseals
Doesn't work that way.
Old May 7, 2009 | 11:18 AM
Run as many or as few speakers as you want. Power remains constant. Doubt if you will over power speakers.
etkms
Jun 19, 2022 06:30 PM
3vilbunny
Jul 18, 2017 05:10 PM
bcoffee20
Nov 19, 2015 06:39 PM
